there are differences in the cut, as 33 &32 GTR bumpers are different in their angles
"universal" ones will not fit both or any that well tbh.
the ones we do are made & sold here in Japan, for each model (not the 34 tho)
cost $170 shipped if your a SAU member :)
normal price is more like $200
if you want a set all i need is
full name
delivery address
email address
contact number
car type
what is the sau price for r32 gtr n1 vents and intercooler surrounding in carbon?
Hey mate
I put some carbon N1 Vents in my front bumper on my R33 GTR, got some before and after shots for ya. I got mine from Just Jap, they fit ok but no where near as near as factory fitted ones. I reckon they would look pretty good on a s2, it would certainly be different any ways, stick out of the crowd a bit.
BEFORE:
AFTER:
The only tips i have would be mark it out smaller than you would normally as the plastic bumper is very soft and easy to cut, then i used a drill with a 5mm drill bit and drilled the out line of it, then used a hand file slowly bit by bit shaped it until they fit in nice and snug, then gave them a good dose of sika flex to keep them in. They were a bit of a pain to do but got there in the end, you will also have to cut holes in the reinforcement bar aswell with a angle grinder and 1mm cutting disc.
As for the door trims, from my knowledge all R32,R33 and R34 have the same Interior trimming, except for a few little things but yeah should all be the same.
  • 3 weeks later...
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
