alright so i got onto it this morning with perth finally seeing some cooler weather
first up i made a stensil to transfer onto the bumper
used the body line of the bumper for placement on the car
used a drill to cut most of it out, i used a 10mm on the first but used a smaller 5mm on the second side, which was a smarter move
still took a little bit of finessing to get them to fit,
tried to fit without cutting the reo but it cant happen unless u cut the vents, so out came the grinder, and just notched the reo,
now they didnt fit perfect but am very happy with the end result, i just realised i havent taken a photo of the end result, but i will when i put the bumper back on, just waiting for the sickaflex to dry
these are "GT-R" vents made for the curve of the GT-R bumper, the non GTR one is slightly different (bumper i mean) thats prob why you didnt get a "Perfect" fit
they fit GT-Rs fine :)
glad your happy anyway
we have 32/33 ones back in stock now
Yeh mat I no that's why, it's not that noticable but doesn't quite follow the bumpers radius, pics will be up tomorrow morning, sorry fellas, couldn't believe i forgot the end product myself actually
ok sorry guys here are the pics, as i have said im real happy with the way it has turned out,
and som top views of the vents against the front bar, the small gap is minimal, but for those who are in search of perfection, well u can decide
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
