lol wanna swap headlights before you sell it?
hehe
sure, lol.
i could give you a hand over a weekend and we can get it done, only because i dont think i'd be able to sell it without headlights. :-)
even my bro did his EK civic headlights after he saw me do it. LOL
  • Like 1
wait but you live in Sydney.
Damn! i want those headlights!!
sorry mate, i didnt even realise it was SE Melb.
i guess if i'm even down there i can talk you through it. thats assuming you enjoy your DIY projects. :-)
i'll pm you!
Edited by AaronNM35
I don't know what yard that's from but I bet you my left nut the km's are not genuine. And that catback looks like a Kaki to me. This is how a Nismo one should look.
lol... Isn't that off a PM35 Axis S, Eugene?
Second generation Nismo exhaust for series 1 M35's was similar to the pic above and the first generation Nismo exhaust had twin square pipes out of the muffler
  • Like 1
sure, lol.
I was going to do it for my Ek to give it an EK9 look - if you do not know what you doing do not do it lol i ended up buying new facelifted headlights as I cooked mine
1st gen Nismo (3" pipe - basically the same design as Fujitsubo Legalis) was available from 2001-late 2002.
2nd gen Nismo (~2.5" pipe) was available from late 2002 and should still be able to be purchased new. It had the oval tip. Ask Iain for a pic of it as one came off Stephens wrecked M35.
Either could be purchased with or without the sound deadening valve
The one off Stephens is the same as mine, I think? In which case its a "Nissan Sports Muffler", not "Nismo".. unless they're actually one in the same unsure.gif
No, I don't think they are. Nismo definitely changed the rear muffler for the second gen NM35 muffler to one with the oval tip and dropped the pipe size to under 3"... but perhaps the "Nissan Sports Muffler" could be a factory fitted option whereas the Nismo is a dealer option?
Possibly. Definitely an easy way to determine if tis the same or not, due to the markings on my exhaust, part number included
Indeed (I saw one of these go through Yahoo late last year - for the first time lol).
Difficult to confuse the two if you are looking at 'em, Nismo exhausts have "Nismo" and "Weldina" on them.
Hi Mate,
due to some travel issues with work i have decided to sell mine, if you're interested please let me know. i would be glad to meet up and you can check it out.
http://www.carsales....12796&silo=1011
the price has been dropped to $16,999 and i'm waiting for carsales to update my add.
if you have any questions please dont hesitate to call.
Thanks
Stefan
Nice car, good luck with the sale. I looked at it but the aftermarket CD player and the leather interior are not on my list of requirements :)
Mine is exactly as per pic from Duncan, it's labelled as a Nissan Sports Muffler and has Calsonic stamped on the underneath of it. I believe it is a Nismo option but was not labelled as such.
parramatta road - allimports - will be in the morning
ohmy.gif....make sure you get definately an independent inspection if your buying off them!
The mob next door is much better....Japlink
and if your in that direction go to E&M Unique there cars are even better!....I know I've seen most of them!
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
