Hi,
Just seeing if anyone is heading along? Had a great time last time and got to meet a few of the SAU VIC members which was great.
Put in a leave form today and going to have a bash both days hopefully, was thinking of squeezing in winto on the friday but might eb a bit to much!!!!.
Just sending off my entry tomorrow so hopefully getting a spot.
Matt
https://www.sau.com.au/forums/topic/352326-piarc-phillip-island-12th-and-13th/
  • Replies 59
I'm going to try and go and Sat but am going to do Haunted Hills on the Sunday (another option if you are interested. Plenty of SAU people will be there - although if I was you I'd be sticking with PI for 2 days)
i have been told some stories about how quick you are mr snowman around PI, hoping i can tuck into your slip stream and you can pull me along :)
Last time i went to PI for the weekend the Haunted hills event was on at the same time as well which was a real shame. Looked at some of the footage and looks like a hoot.
Interested in splitting the cost of a garage on the Saturday?
Matt
Edited by boxheadmr
I posted my forms last week with a cash cheque for the saturday, would have been heaps easier with EFT and faxed or emailed entries, spose I will find out on the day if they accepted it.
Really didn't think I would ever need a proper cheque book.
Gonna try fit oil cooler this weekend, then should be ready to go.
I'm staying down on saturday night for a few beers, then going to the track on sunday to watch a few friends peddle their cars around.
Look out for the silver 32 sedan.
Cheers
Rob
Will be going down on Sunday for a look....
Hi,all,
I will be doing sunday at PI if my blue/black S15 is OK after saturday at Sandown with Driver Dynamic. A double header this time.My mate Dale will be doing the same two days with his GTR33. look forward to meet up with you guys.
Try to arrange accomdation for Sat night at PI, any suggestion?
Alex Cheung JAK Motorworks 0433878905
Well, don't want to jinx myself...but with these late night ass bleeding hours, provided Fri, Mon & Tues go to plan i should be good for taking thu/Fri off which means I am good to go. Will call PIARC when i get a minute to confirm space on Friday this week.
roy, i sent my entry form early this week so if you hear it is full would you mind letting me know please. I really hope not as i just booked accommodation:(
Alex, Accommodation at the Phillip Island ECO Lodge if you have some friends seems most affordable and still OK, we booked a 2 bed villa Fri-Sat and Sunday nights. If you are going let me know and i guess drop by for a cold one.
Looking forward to meet up with you at PI.my mobile is 0433 878905
Alex Cheung and Dale Kennedy
I cant come. :wacko: Pretty pissed off ATM. Its the last weekend we have our holiday house. We sold it and the settlement is Monday.
Apart from weird little huts to sleep in, the Eco lodge is pretty well equiped. They have a big pool and outside BBQ. Seeing you guys will only be sleeping there basically. It will be fine.
Have fun :action-smiley-069:
Edited by Tektrader69
Hi, met up with Matt and the boys and share the garage.had a great time at PI.unfortunately my S15 drop a cylender at Sandown on sat otherwise I will have a ball chasing Matt's gun S14.will have mine rebuilt quickly or swap the 2.2 stroker SR20 I got from Japan 319kw on pump fuel with a TD06/25G. look forward to the next track day.
was not the best weekend with miss firing that i thought had been fixed and then cracking the turbo manifold most probably due to the miss firing and having to run as little boost as possible.
Was nice to meet you all and whilst with all the troubles it was probably a weekend to forget it made up for it having a chat around the garage and seeing all the cars out on the track.
I have put together a clip for my tuner to try and work out what is the problem and replicate on the dyno but it gives you an idea of my frustration.
The running around with little or no boost and the big crack in my manifold was fun for a while until smoke started coming into the cabin. Might have to wait another couple of years to be able to afford to head down again but hopefully it will just be the driver and not the car as the limiting factor next time.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
