I bought a rx7 three years ago and have since rebuilt the car from the ground up, put in a s5 13b turbo, completely overhauled the interoir, 18" mags, custom paint job, custom bodykit and lots of electronics and motor upgrades. Over $15000 was spent.
Two weeks ago i received a letter from savings and loans saying i must surrender the car to them due to an unpaid loan. i didn't understand this because i paid for the car outright. when calling them they told me that a loan was taken out six years ago for the car by a past owner and $5900 was still owing.
After seeking legal aid i was told i could either pay them $5900 or surrender the car. due to financial diffuculty as i am now a uni student and no family member or friend willing to help me out i had to give up the car.
Legal aid asked why didn't i get an encomberance (outstanding loan) check done on the car when i bought it. being ninteen i had no idea such a check could be done.
I have found out now that checks can be done for $10 at any registration department.
If you or anyone you know know is buying a car privatly or through a car yard, get this check done, even if you know the person you are buying the car from.
I will keep every one posted on what happens.
Thanx for taking the time to read this.
https://www.sau.com.au/forums/topic/35241-read-this-encomberance-checks/
Yeah I had huge dramas trying to sort out REVS issues when buying my car recently.
DOCEP people were very helpful (albeit agonisingly slow), they kept me informed with all of their investigations, progress etc.
The REVS check is free over the phone....
Then you can purchase insurance against the check $10.
(note the insurance only covers you for "registered interest in the vehicle in WA)
I haven't got any nasty encumbered vehicle letter yet (fingers crossed).
Well at least you got a letter - a truck drove up to my driveway and dragged the car off it while i was in Singapore - August 2003. I did do a REVS check, I was aware the car was encumbered, I had the previous owner sign a statuary Decleration that he would pay his loan out with my cheque. He didnt - instead ran to the UK with my money.. I have now have a fraud charge against (as he defaulted on a signed contract) him and I am in constant contact with his bank to try and sort this mess out. What I should have done is made the cheque out to his bank.
I saw about 3 lawyers and they told me about extradition proceedings etc, which I cannot afford. They told me that we fall in a crack in the law where the banks debt comes first, not yours. If they have repossesed the vehicle, no doubt the bank will have some sort of charge against him. YOu can PM me of you want... I can try and help you out as best I can from what I am going through right now.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
