5 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hello I got a set of V35 coupe wheels from a mate for cheap. Two have scratches around the rim and all of them have light scuffing on the spokes. I would like to neaten them up but to get them re-done in shadow chrome is $260 each, way more than I paid for them lol. Anyway the wheel repairer (Depulu) suggested a colour change to plain silver which brings the cost down to $185 each wheel (inc tyre removal/refit), which is much better for the wife :whistling: . Anyway I was also thinking perhaps gun metal would look alright as well. It is a black V35 sedan.
Here are 2 links I found of what I am thinking of
The first is an Audi but they are 7 spoke wheels so sort of close-ish.
Audi with gun metal 7 spoke gunmetal wheels
The second is a set of 18 coupe wheels home painted to gun metal.
coupe wheels painted gun metal
If there are any other colour suggestions fire away. But not keen on black and not not keen on black with red lip.......
Edited by omp
https://www.sau.com.au/forums/topic/352599-v35-coupe-wheels-on-black-v35-sedan/
Black on black.
And then paint the chrome bits in your car black and if you can paint the headlights black.
And you have the nicest looking car.
Cant agree more, okay this is not the sedan but this just looks the business! GO BLACK!
A chap posted this on BC.com. They aren't the coupe wheels, but are close. I think if the wheels were dished, hellyeah black with polished rim/lip. I am just worried with black wheels it will be to much black?
Edited by omp
You can buy tint for the headlights to tint and it looks pretty schmik , I am bout to go ahead and get everything blackafied (just made that word up) , got grill , indicators and new headlights to play with as well as black wheels so should look good
Hello Back again, using my non existent paintshop skills I used the wheels as shown on the Stagea (both in the light and shade) above and also found some pics of some V35 coupe wheels painted gun metal grey. I do like the tungsten in the shade but not so in the light. Suggestions?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
