im a maybe now, its going to be another late night up at Mt Barker
Dion, will work out getting the swaybar to you
Luke, i'll pop the ignitor in the car and take it to Mallala sunday, cos no doubt you'll pop your head out there ;)
Have you actually bought an R32 Tim?
the bank bought it for him...and he has to pay them back :domokun:
Thanks Steve, it goes pretty good. What spark plugs would you suggest for it? it's got 250.1 rwkw
I thought it had 205.1rwkw!?
you bought it from my cousin. f**king small world I tell ya.
Copper plugs would do the trick Chestnut :D
Is that who it was? He mentioned your name when we had a look at it. He asked me "Do you know Krishy?", I thought he may have been a relative of yours.
Fellas,
IM going to have to cancel tonight for me....
I have had some issues over in melbourne with buying another car and i wont get there in time as i am still in Melbourne now ... SPEWIN!!!!!pinch.gif
I will make sure next time im down to head down for a meet n greet.
Apologies
Matty
I wouldnt put a 2530 on a RB25, bit too small. 2530 on a RB20 however fits like a hand in a glove. On topic, I'm a maybe for tonight now.
If you do come down, don't forget the valley cover from the rb20 please
Bollocks ... I had an HKS 2530 on my R34 and it went like stink ... made a very lazy 230rwkw with only a very conservative SAFCII tune. Oh, and ZERO lag.
And 1) I have NEVER seen a stock turbo on an R33 run 215rwkw, and 2) if it magically did, for how long, and how hard were you wringing its neck?
As I said, my 2530 made a LAZY 230 behind an auto slush box, with no aftermarket timing/tuning (just an SAFCII), with standard injectors and fuel pump. Of course it could have made a shit-ton more if I would in more boost, got bigger injectors, bigger fuel pump, better tuning etc .... but that is not the point.
it did, and has done so now for 3 months or so, including the track day and plenty of driving. Just dont see the point of a turbo swap for such a minimal gain. thus why i went the 3076 to replace it
also in the 'post your rb25 dyno charts thread', there are a few freak motors making 225-230 with 15psi. yeah it may not last to long, but can be done. sometimes a set up just works
when i had my 33 it made 210rwkw on 12psi with stock turbo.... had power fc, front mount and exhaust
it made 185 before the power fc with a remapped computer from japan... i dont know what type was in there when i bought it
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
