  • Replies 163
Posted Images
for the r32's do the injectors have to be Hi-Impedance?
ive got 700cc siemens low-impedance in my 32 atm . . .
does your 32 run the same low impedance thing that GTR's run?
well ive got a microtech in mine atm, changed the injectors and had it tuned ran fine, now that ive gone bigger turbo and re-tune, the injectors? seem like they are cutting out at 6.5grand then come back in. . . would this be because there low impedance?? only asking because you have the high impedance listed as the ones for 32's. . .
sorry i don't know the answer to your questions, maybe ask the guy that installed and tuned the microtech how easy it is to go back to high impedance
hi Joel for some reason i cant find your PM did i reply to it
can you please resend your exact order again
is there anyone else i have missed
who is Joel, im not sure
just a few days left people can you please check you order and calculate the price your self just in case i got it wrong
yep No problem, you can pay in person if you like
your realise you will have to space your fuel rail up Simon will be able to help with that
and do you want the wiring adapter for the Z32
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
