Hi, i was wanting to know how much the RB20DET box can handle? i now it would be best to get the RB25det box, but at a third of the price its hard not to consider the RB20det box. my car is a relatively stock (for now) R33, my goal is one day to have round the 250-280rwkw mark, with track days etc in mind. will it be fine with just a better clutch or what?
Cheers
https://www.sau.com.au/forums/topic/352978-rb20det-box-on-rb25det/
RB20DET is a piss weak gearbox. I wouldn't put one in a stock RB25 street car, let alone tracking @ 250rwkw.
Also, FYI an uprated clutch puts extra pressure on the gearbox, not the other way around. It's meant to be the weak link in the driveline. What's wrong with your current gearbox?
also depends alot on how you treat your car/box.
i have a 20box running behind a 30DET with 285rwkw and a bucket load of torque. its a track only car too, been going good for two years doing motorkhana's, texis, hillclimbs and normal track days.
i figured i could go through 5 for the price of one 25box, but yeah, so far so good.
Yes, you would have to reconvert everything as the RB25 is a completely different box. Do it properly first time around and get an RB25...there's a reason Nissan didn't use the RB20 box in the R33. If you blow up even one or two boxes, the cost and time to replace won't have been worth it, not to mention how bad it feels retiring from the track with no gears :)
you'd have to feel awesome but, like my car is sooo powerful it munches metal cogey spinney things!
Really is a valid point though.
Hahaha, or the sad reality in most cases "I can't drive a manual for shit".
I'm very surprised you've lasted this long with the RB20 behind an RB30ET. Very lucky or you know how to take care of it I'd say. There are that many people who blow up the RB20 box with little more than factory boost. How much does your R31 weigh in race spec? Might factor into things, as you can run piss weak boxes behind lightweight Cobra kit cars with big V8s all day long and have no issues at all.
I also had a couple of years with a 20 box behind a 280odd rwkw rb25. Ended up removing it and selling it to upgrade to a 25 box before the inevitable death and zero resale.
This was in a full weight 32gtst.
It did get a little noiser over that time but still shifted fine.
Mechanical sympathy and a sprung centre clutch is the key.
just lucky i'd say. i break stuff alot.
when i last weighed it, it was 1150kg dry. so +100kg for me, say 40-60kg for cage and 35kg in fuel.
maybe 1300-1350kg
tyres are 235 fedi RSRs and a sprung centre 5 puk with 4000 pound clamp load & carbonic? pads. maybe combination of lighter weight, smaller tyre contact patch and clutch help
i actually dont want to break the box, i got a case of piss saying it'll last 12 outings.:rolleyes:
I have a rb20 (nics) if it makes a difference behind my rb25 in my coupe! Car makes around 180rwkw not to sure but im having it dynod friday! Has lasted about 2 months now. But i don't drop the clutch on it hard etc, but i think it comes down to the clutch too! I have a heavy duty clutch in it from when i bought it but i need a new clutch so if i went a too harsh clutch it would probally break after a while..
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
    • You can trust Rezz!
    • Just to get this straight if you turn the splined shaft to the outside, it turns freely but the chain does not move? What happens when you move the chain, does the splined shaft turn? Surely the shaft is snapped, or the chain is seized and it took the teeth off whatever great is behind the steel bracket
