  • 3 months later...
I have to update this for Steve, as Im just as excited as he is. Big props to Powertune and everyone else involved, but we were out testing yesterday (His our again today), and what an awesome shakedown. I wont post any times or details, ill let Steve do that, but here is a pic
So after the cage getting painted the engine and gearbox was dropped off for installation in March. Work up until this point was faultless. I was quoted 4 weeks until completion.
April....... Wife cancer
May........Kid sick
June...... Kid not his
July.... Separated from wife
August.... Bikies after him
September... Bikies poured sulphuric acid on his hair and my legs were broken
I genuinely felt sorry for the cnut. I have succumbed to the fact that he is mentally not there. Through my observations and from my opinion (medically based) he is a compulsive liar (only the seperation part is true) which makes it very hard to deal with. Just check out his trader thread. That has only unravelled the tip of the iceberg...believe me! . I'm not here to discredit his business even though he has cost me tens of thousands through missing parts, engine failure due to poor workmanship.
So lets move on to the awesome part ;)
I had to goto the workshop to hijack my own car with a few mates unannounced. As I have a car to prep for wtac ;p
VSPORT next stop... Brakes, suspension, dry sump sorted! Superb efforts there from Todd and Johnny
POWERTUNE to finish the car for testing.... Fcking awesome gig they run there! They do everything!!!
HALTECH - so generous with time and support and such a awesome product when understood
Justin from PROWIRE who wired the whole car up without fault on the first start!!! Drops panties bro lol
Anyway.... Shakedown was frigging awesome. Could not fault the car mechanically. Haltech setup my whole data logging trackside and once again there efforts are above and beyond.
I destroyed my front left canard yesterday collecting a witches hat under lock up but I'm still getting over the novelty of clutchless shifting :P
Boz doing what he does at TRACKSCHOOL tested the car............. Video to come .......
I can't believe it's this quick out of the box so early in its testing without any aero and on its run in tune.... And weighing in at 1420kg :P
Ur "mate" did the dash I think haha
That's right.... ur mate that sent away ur exact brakes lol
just alloy wrapped in carbon.
Shifter is a custom made extension by powertune on a pivot to give the exact same consistent throw to the holinger plus signal to the Motorsport systems strain gauge shifter. It also gives the driver a back and forward feel.... vs the easy dog leg option which gives inconsistent and weird angles of thow. All this because the seat position is at the passengers rear foot rest ;)
Mouth watering for sure!
Big novelty for me at the moment pulling that big knob...all I'm thinking of is getting to sixth and bleeping the throttle on downshifts on the peddle box. Until I'm comfortable with that ill start zoning in on my lap times :P
Car is looking awesome. Can't wait to see some shakedown vids and the car out at WTAC!
Who was this in refernce to?
May........Kid sick
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
