Hi Everyone,
Its time for our annual Dyno Day. if you would like to participate please put your entry through sooner than later.
We got (from memory) 44 cars last year and had to turn down about 10 so there is a limit on how many we can do.
It is a 4WD dyno so all types (FWD, RWD or 4WD) are welcome. For the R34 GTRs I know you will need to remove the rear diffuser.
(9th Feb 2011) There are 15 spots out of the 40ish max taken already, so be quick.
Previous Pics: http://www.gtcarclub.com/Resources/!events/20090719DynoDay/index.html
https://www.sau.com.au/forums/topic/353321-19th-march-2011-gtcc-dyno-day/
Hey Gents
Yah I know it is near Knox. Seriously even when I had my R33 GT-R I never had any issues @ Knox and I was there every 2nd day but I am not saying you guys won't/don't.
VCM Suite is on Ferntree Gully Rd so you do not need to pass Knox.
You guys don't realise but Pettite probably surfs these forums regularly and if you state you are trying to avoid Knox the more effort he will make it to come down :)
Sorry guys I cannot gurantee what I have no control over but the last 2 times we have been there, not a cop in sight.
Hope you guys still decide to come down if not to Dyno, for a look see.
Regards
B
PS: Sorry didn't know it was on the same day as DECA.
PS2: Thanks to those who have already paid.
Are there any more spots?
I have never been to one of these so what the procedure/format of these event? Do your cars have to be modified or anything or just anyone with preferably skylines involved?
Age limit? (lol) I am an oldie (45)
Regards
Dazza
Regards
Dazza
Spoke to Brandon last week, said there is still spots so quick get in :)
Can be any car, stock or modified hell my GTR is stock as a rock and going on :D
No age limit!
Thanks for the reply Leigh
Yes guys, your car does not need to modified or expected to deliver large amounts of HP or Kws.
Some people use it as a comparison when they are about to do Mods, since we try and do a Dyno day every 12mths, they can then compare what sort of performance difference their mods have made.
Others just like to be able to analyse their power curve.
Others just like to participate and check out the different cars.
Im Surprised but we still have spots left.
Thanks
Bran
Hi Guys,
We still have some spots left.
I will be emailing the timetables on Thursday sorry but I need to sit down and work it all out :)
Some people can only make it in the mornings etc etc
Even if you are not dynoing your car please feel free to pop by grab a bite take some pics and mingle.
Thanks
Bran
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
