  • Replies 66
Maybe Admaz, on the cruise tomoroow you could apply the suplex or pile driver manouver on James, get him and the gang off their bums to finalise the VIC thing. I seriously think at this stage that's all that is holding the deal up..[james can confirm]
Yes, it will include flywheels. As not to step on other distributors toes, they suggested to limit SAU to Skyline/Nissan models only & anything from heavy duty up.
..[Jamezilla can confirm]
Shouldn't be taking this long???? Also be on the look out.. once Jamez sorts out this VIC thing out, I have a contact at a tyre manufacturer lined up to supply SAU permitting. ps: no crappy make either :) [spelling] OH-FEED-EL-SHUN :D
hey buddy... i'm defintiely in need of a new clutch, considering i have just completed some engine work and my standard clutch can't handle the extra power; so it's time to spend some MORE bloody money..
i'd be after a new clutch system and a lightweight fly wheel.. how far away are we to this deal, in your opinion? i have a track day coming up, so I would probably need to get it after I completely kill the clutch on the day.. so ASAP would be great..
cheers man..
Giles
there is a hand full of people here who need a clutch asap.. is there any way something can be arranged for now? maybe a group buy of heavy dupty GTR/GTST clutchs from your rep? pls guys alot of us are waiting on you!
OK Guys below is a list of people who ergently need clutchs and have expressed interest in this thread. Can we organise either a group buy or a discount for buying so many or some sort of club discount asap.
Stirlo_GTR
gts4_fun
vendetta
Adzmax
Bass Junky
benm
myr332
ajmck
Black33
MM2death
gatty
phorj
NickR33
Blitz_R33
Gizmo73
ed R34
*plus I am sure there will be more if something takes off..
Aaaah! forgot to give an update.. sorry guys.
Here's where we are at,
I pretty much secured a deal where SAU would become a "licensed distributor" on all exedy products limited to skyline models. They needed some other details which I felt would be best handled by the senior/pensioner/war veteran :P SAU guys, so I have handed everything over to James "jamezilla" and hopefully he will keep you updated.
I wouldn't expect to see this happen any time too soon, I'm after a clutch and flywheel too but I don't think it will go ahead untill the Vic SAU is up and running. If Mesh or James are reading this can you confirm??
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
