Hi guys,
I played gt5 for the first time last weekend and i loved it! looking to get a ps3 of my own. Does anyone have any hook ups or know where the best bargains to be had are? Im located in the liverpool area, but dont mind driving around sydney to get it.
thanks!
https://www.sau.com.au/forums/topic/353345-ps3-hook-ups/
but in all srsns
http://www.ebgames.com.au/ps3-999369-320Gb-PS3--Dead-Space-2-LE--Gran-Turismo-5-PlayStation-3
i hate myself for pimping EB. deadspace2 and gt5 + 320gb ps3 for 600, make sure you get a hdmi cable (any brand, can be cheap, they still work)
there's one at jbhifi
http://www.jbhifionline.com.au/game/ps3/ps3-playstation-3-320gb-console-bundle-gt5-final-fantasy-xiii-ashes-2009-hdmi-cable/632519
guaranteed you'll throw out FF13 cause it's poo and ashes... if you're into cricket...? if not, meh. they have a cable with it but they're a negligible cost.
https://www.sau.com.au/forums/topic/353345-ps3-hook-ups/#findComment-5663281
You won't find PS3's cheep, no one discounts them - unless your buying 2nd hand. Just look for the best package deal. I think I bought our 1st one with $2 off.. came with 2 games for like $479 and the 2nd one I bought with a 32 lcd bravia for 1100.
https://www.sau.com.au/forums/topic/353345-ps3-hook-ups/#findComment-5664271
Not necessarily - if you can afford a decent HDMI cable, go for it. Regardless, make sure it's properly insulated, especially if you'll be running it next to power cables or if it's gotta stretch a long way.
I took my PS3 out with me a few weeks ago, and luckily brought 2 HDMI cables with me - the first one would barely work, and when it did produce a picture it had heaps of interference. Plugged in the second one, and problems solved!
https://www.sau.com.au/forums/topic/353345-ps3-hook-ups/#findComment-5664534
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
