Lol how da hell do u get a room during the day!!!!
A. Loan me your girfriend
B. I will show her the ins and outs of getting a room during the day
C. She can then educate you in the above process.
Easy peasy, What day is good for you ?
  • Nope 1
Hahahaha dont worry fellas havent gone anywhere just been busy at work. I guess what I meant was, arent check in for rooms at 2pm in da arvo or sumtin, hence why i thought it was out of the question.......but i suppose i could give a couple places a call and see what they have to say.
Lol some good humour in here i must say!!!!
When you send your lady friend a text, do you write the same way that you post here?
Like do you say, "hay Babe.. 2moro in da arvo, we can do sumfin in da car at da look out an den I gotta drop u off at dis old geezas place 4 da bbq pig on da spitz or sumfin"
If so, does she still talk to you?
Are you Gen Y?
He doesn't post nearly that bad. Maybe i'm getting older and mellower and just don't give a shit, but seriously. As much as its tempting to be anal about it, i can perfectly understand what he's writing even if he uses the wrong grammer and misses out a few letters/words.
Besides, there's much worse, like the example you gave.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
