yeah its disapointing lol, i did a simliar sort of thing with my car.... but its not 100% (had only just started using photoshop)
Have a funny feeling I posted this one up before but anyway lol
(if you cant spot the problem, look hard at the tree on the right lol)
I think this might have been uploaded off my iphone.... the quality doesnt look great, but you get the idea
Edited by 89CAL
  • Replies 204
If some one wants a set of RB25 runners let me know and I will bring them down to Airlie. Will save half the cost in freight.
http://www.skylinesaustralia.com/forums/topic/359381-rb25det-standard-intake-manifold-runners/
Ok I think I will update the first post with who is going and more details.
There have been a few people that said they might go but havn't replied in the thread for a while. So will wait for them to let us know to see if anything has changed and then I will update the first page :)
If i have my new evo x by then ill bring it down should have it in a week or two hopefully, its no skyline but there arent that many Evo X MRs around and they are a awesome car.
Farkkkkkk. How had I not seen this??
I am pretty keen to cruise up from Rocky. Where did you guys end up staying at? Might as well all stay in the same area (even though airlie is tiny).
Or are places booked out by now (being close to easter)
I will baby my car up on the 20ies, fingers crossed there is no large pot holes :huh:
Yep definetely man! Would love to have a good look at one up close.
Awesome dude, looking forward to seeing your car, and the rims!
Me and Rob are staying at this place:
http://www.marinashores-whitsundays.com/At_Marina_Shores_Home.html
The other place we originally were looking at ended up being booked out. Perhaps call this same place and see what is available. Hit up some of the other guys to share a room or something. Or just fucking crash at our place on the couch or something lol.
you know im comen so put my name on it if ya want.... more names looks better hahaha
and well my name is sure to attract a few more
be good to catch up.
hows the engine conversion coming along?
Me, Callan and Nick are 100%. We've got some place in Arlie booked that the fiance found. No idea what it's called, but it's close to the pubs and stuff apparently. We're heading up on the Friday and coming back Sunday.
Checked out most places. All booked out pretty much. I'll confirm if anyone is keen to ride up with me, and if so might just shack up on the floor in your room Paul?? :teehee:
I can imagine it will be a rather boozy night, correct? :banana:
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
