Hey guys,
Dont want to remove the head on my rb22 to drill out the oil restrictors, as my head is overly restricted for running tomei valve springs, too much seat pressure. Want to leave the head on it so that everything stays 100% perfect in that area.
Restrictors are 1.0 front, 1.2 rear. I believe Tomei reccomends 1.5mm front and rear for hydraulic head, and some other aussie companys reccomend 1.3mm front and rear. So mine obviously too restricted, hence the lifter noise.
So for $1300 i can go solid lifters and cams from tomei. Then sell my camtechs, recoup some money, and have a better engine for it. So thats how ive convinced myself haha
But still struggling to decide what size cams to go, I have tomei valve springs so they will handle anything i throw at it.
Options are
260/9.25mm
260/10.25mm
270/9.25mm
270/10.25mm
Car is street driven, gets a very hard time and will be used for some fun track days, no real racing.
Turbo on it at the moment is, due to budget restraints, RB25 stocko. Will later be changing turbo to most responsive 230-250rwkw.
GTR bottom end with N1 oil pump, stock harmonic balancer, Should be able to rev to 8000rpm ok.
Has camtech 268/9mm in it at the moment, idle sounds tough as but havnt driven it due to lifter noise so cannot say if power curve has been shifter up and right too much.
Leaning toward 260/9mm for better drivability, and its still alot bigger than standard.
Happy to listen to good discussion and valid examples etc etc
https://www.sau.com.au/forums/topic/353670-rb22-going-solid-lifters-which-cams/
Apart from the lift side of things the stock r34 gtr cams are fairly close to the specs of the stock rb20 cams.
Check out this link: factory cam specs
Out of those tomei cams i'd definately go the 260/9.25 for the same reason you give. To make full use of anything bigger you'd have to do some porting.
Edited by Dobz
Well, how much farking around has it taken over the years for the RB26 guys to learn the best combo of head, exhaust, cams and turbos? Nobody is playing with RB20s so it is taking me a long while. If i can get about 280-290rwkws with about the same response as I have now out of a $600 wrecker engine then the experimenation has been worth it...still well under the cost of a built RB26 with the -5/-7/-9 setup :)
I would actually look at running std RB26 cams before anything else. The R34 runs a difference CAS so ot sure if it talks to the ecu you are running?!?!?!?!
Ecu is nistune on the RB20 ecu, I could pick up a set of r32 rb26 cams for next to nothing im sure.
Having said that in SRs and CAs ive always had 256/264 drop in cams, and only saw benefits. So i cant really see why the 260 would have much loss, but happy to listen to people in the know!!
Apexi cams seem to use ramp rates different to others and can be tricky to get results from...well so the story goes. Here is my dyno sheet of an internally std RB20 with full Greddy TD06-20G setup before and after Apexi 260/9mm cams. I dont need to explain which colour is what...the std cams went back in so should tell the story :)
What dobz said, the Rb20 runs a fair bit of cam for a 2L. Remember that the 2L is spread accross 6 cylinders and not 4 so the air to each cylinder and combustion chamber is different to a 4 cylinder and its easy to over cam a 2L six and lose all velocity and cylinder filling...or so it seems. :)
Still deciding trent, only thing stopping me pulling the head off is wasting that greddy head gasket. I have a cometic on the shelf that's new.
If I use gtr cams with tomei lifters it won't cost me anything once I sell the other cams and I'll have a much Better engine for less work??
The head has been evolving each year or so - leave that outta the equation. :)
But you've just spent so much coin man and NEVER gone forward. Always lost response or power.
Im all for chasing that last 1/10th extra, but you've never found it. Get out there and drive it!
Yeah, and look at how long the gt2860 thread is, not to mention how long the over 400kw thread is....
People still cannot point to a solution and say " It makes this power at this revs with this transient response because..."
X says you have to use 30000 degree cams with a big lift
Y says Nah Mate use standard cams
Z says I dont use cams a wizard makes my engine powerful
etc etc.
Edited by Nee-san
Gtr 240/8.5ish cams with tomei lifters or 260/9.25 with tomei lifters???
Anyone made solid inserts for stock lifters??
Hard decisions, either was 268/9mm whats in it now is way to big right?
Even if i go solid head then 1.0 F 1.2 R reistrictors is way oversize for solid head right?
Half seems like i should drill restrictors and put stock cams in it.
Someone tlel me what to do this is shit haha
GTR cams base circle 32mm, tomei cams which work with there solid lifters 29mm. How thick are the shims normally used in the lifters, as in if they are more than 3mm then i can use gtr cams with a thin shim. If not more than that then cant use gtr cams.
Have you checked the valve stem length differences and whether you can use the GTR lifters in a 20? I have two sets of Tomei solid lifters for VG30, RB20/RB25 and they are different to RB26s and RB25 Neos, to the point that the RB26s obviously have longer valves ?!?!?! Intersting to see how you go
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
