Here i have a turbosmart megasonic BOV for sale! its missing 1 trumpet but is in very good condtion!
also has RB adapter also!
Taken offers please! PM offer as i want it gone quick cheers!
or ring or mge me on 0404 232 231 cheers clayton!
still 4 sale cheers!
$150ono
Offsets look standard. I guess 38.
Width of the rims are 8.5" with 225/35/19 rubber on them.
$1100 ono
:D
If sold by/on the weekend $800 ... $800
Need quick sale ... got my eye on something.
Garrett gt30/82 (gt30/40) .7 front, .82 rear, external gate, turbo approx 5000kms old, no shaft play, in as new condition, made 300rwkw on my rb25 340rwkw on e85, awesome midrange/topend power n torque
used with 6boost manifold n gate, full boost (23 psi) 4100rpm comes with 3 inch dump from turbo, $1500
BLITZ number plates (SA), gold lettering on black background. $500
Matt, 0422976559
Still for sale:
Greddy Type S Bov with RB adapter = $200 firm
bare vertex rear bar = $200
R32 Steering Wheel= $50
Greddy Turbo Timer = $100
vinnie, I pmmed you about the steering wheel
why havent you replied?
-Dohmar
4 x stock R33 wheels with tread.
Painted black. pretty shitty paint.
$200 the lot.
If anyone is interested PM me and ill take pics as Ive forgotten what the tread is like
Got 4 Standard 33 Rims with excellent tyres, they are painted black, paint is pretty good condition, no gutter rash.
$250 firm
comes with wheel nuts, lock nuts and lock nut key.
are these the same? or two different sets?
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
