mums daily car,
she doesnt need it anymore wants me to get rid of it.
91 KF laser, white, manual, 1.6L carby, think its just under 200,000kms or maybe just over. Runs fine, new cv joints, new brake pads, water pump/timing belt done less then 3 months ago. comes with 15" alloys, however one tyre is bust and is on a stocky. very very cheap on fuel. Battery less then a year old. Bit of paint missing on rear bumper but its cheap!!! Rego runs out soon.
$1,200ono.
pm me
or 0422 314 938 (Marko)
TRD sticker can be negotiated with the purchase :P
Can get pics on request but come and see it in person, take it for a test drive or whatever!!!
Item:
RB26- R32/33/34 complete oil cooler kit for sale with stainless hoses , filter holder + brackets
18 row cooler , complete with all adaptor fittings was $400 new
Item condition:
:P New
Contact details:
Please pm
Price:
$220 - or Reasonable offers !!!!!
Pics:
Drift special tyres, still lots of legal tread ??
235/40/18 x 2 Firenza ST08
some inner wear but not on the wear bars yet.
you pick them up from down south, $ 40 for the pair
PM... first one gets em.
wrecking s1 r33 in silver im keeping these parts but everything else for sale, the car has rear end damage
KEEPING: gearbox, front brakes,tail shaft,steering rack,front lower control arms,
THE ENGINE IS A SERIES 2 complete engine, loom,ecu
completely stock, never even been boosted.
still in the car so can hear running, compression and any other tests welcome....$1800 $1600
OTHER PARTS:
bonnet $100
S1 front bar $80
lh guard with indicator $100 each $80
s1 headlight $80 each
rh complete door $150 each
s2 spoiler $50
rh mirror $30 each
type m sides fiber glass $100 $80 needs bit a work
fuel flap $10
rear window $100 taken out
quarter glass $80
radiator $100
condenser $50
condenser fan $50
master cylinder non abs $80
washer bottle $20
cluster $100
dash $100
mint air bag steering wheel with clock spring $140
seats $100 pair
glove box $20
console $40
door trims and 1/4 panel trims $40 each
seat belts $20 each mint
indicator and wiper stalk $25
rear seats $40
manaul conversion pedals clutch master interior boot trim $150
anything else just ask, will swap for parts of interest!
LOCATED IN ATHOL PARK...TEXT or CALL on 0422030855
Edited by hcR324door
mums daily car,
$1,200ono.
pm me
TRD sticker can be negotiated with the purchase :bunny:
SOLD
S14 front 4 pot calipers + rotors $220
includes pins, shims, stock lines, good Bendix pads, slotted RDA rotors
Broken S14 SR20DET gearbox, 160,000kms old $60
Blown second gear, good for cut and shut bellhousing or rebuild
Factory S14 SR20DET sump $make an offer
Taken out of car to upgrade to bigger baffled unit
Whiteline eccentric camber adjustment bolts KCA414 $50
Adjust camber on the front struts, 14mm bolt, suits S14 and lots of others
180SX factory quarter window visor thingos $make an offer
a few clips broken when removed from car
R32 handbrake cables $20
Stock S14 swaybars $30
Can provide photos on request. Prices somewhat negotiable.
Located north eastern suburbs SA. PM or SMS 0424085308.
Still got 2 sets of suspension to sell
$600 for Bilstein R32 GTR/GTS4 - provides a nice balance between street and track performance, but is not street legal due to eyebrow height
$500 for Tein HR R32 GTR/GTS4 - stiffer than the bilsteins, so more oriented to track use, however these actually ride higher and are street legal
and I can still source injectors for those who want it. Windowshoppers and shoegazers can get f**ked. PM me only if u want to buy, I dont tolerate time wasters
-D
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
