Drift special tyres, still lots of legal tread ??
235/40/18 x 2 Firenza ST08
some inner wear but not on the wear bars yet.
you pick them up from down south, $ 40 for the pair
PM... first one gets em.
tyres sold pending payment and pickup
Xtreme Heavy Duty Cushion Button Clutch for RB (Push Type)
heaps of meat left on it (only used for 15,000 kms)
price drop $200
need it gone, engine being rebuilt soon!!!
pic: http://i37.tinypic.com/29zu3bd.jpg
pic: http://i35.tinypic.com/c84l3.jpg
pic: http://i34.tinypic.com/2a4tvte.jpg
pic: http://i35.tinypic.com/sfjo9l.jpg
pic: http://i33.tinypic.com/iog2yo.jpg
pic: http://i38.tinypic.com/sqo41h.jpg
pm or 0413 733 433
thanks
PICTURES ON REQUEST
PM OR TXT/CALL ME ON 0432716315
Series 1 front reinforcement/reo bar, not cut but a tad bent but wont matter. Still fits great and still legal - $100
Series 2 front reinforcement/reo bar, cut but only 2 slits at the front bit. Not noticable by the cops, have been pulled over with a front mount and that reo bar in and cop didnt notice, regency will though - $100
Rear bar painted in white 8 months ago, bent in a bit but can be easily heated out - $40
Isotta steering wheel R-EVO made in Italy w/boss kit to directly fit R33 great condition, as can be seen in picture, ADR approved - $200
Stock Airbox - $100 (No snorkel) comes with a filter (may need replacing)
Windscreen Washer bottle - $30 mint conditon
Non Turbo series 1 cluster w/ 168,471km's and white dials in working order- $70
Turbo auto series 1 cluster w/109,671km's in working order - $90
L&R mirrors in white - $20 each with motors in them
Fuel cap in white- $10
RB25DE Non Turbo series 1 engine loom, ecu and fuel pump GREAT FOR CONVERSION - $200
4 x 4 stud hubs + 4 x 4 stud rotors plenty of meat left on them - $200
Non turbo rear brakes w/pads - $50
Glove box - $30
Centre reading light/Main light - $10
Sun Visors - $10 each
2 x Seat belt buckles in great condition - $5 each
Rear view mirror - $10
Some left over parts for sale, reason for sale is I no longer have a 32.
1. Upper control arms with Nolathane bushes - $80 Took them out after going Regency and had adjustable ones in
2. Front strut brace Jap - $70
3. Air con vents for 32 - both Passenger and Centre Excellent condition!! - $70 each or 2 for $130
4. GFB black stealth MBC - $30 (went with an EBC instead)
5. 52mm Gauge cup holder - $20
CONTACT: Andy or PM 0425008999
PICTURES ON REQUEST
hi would the boss kit and steering wheel fit onto a r32 gtr?
Glove box - $30
R32 GTR "side pipe"
must stipulate, this is for TRACK USE ONLY!
bolts up to end of the Y merge front pipe, replaces cat and rear pipe with a 2.5" mild steel pipe. Goes to rear cradle, turns and dumps just before the rear wheel
Its loud as buggery, but thats what a side pipe is for
can get some pics
$150 (basically the cost in materials)
CONTACT ME VIA PM / EMAIL IF INTERESTED
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
