selling for a mate,
r33 rb25 gearbox from a completely standard car he wrecked 104xxxkms on the clock $900 o.n.o
r34 2dr doors complete, motors glass $180 each
34 door trims $45 each
34 tail lights $150
boot lid with gtt spoiler $150
34 radiator $80
34 rear bar $150
34 bonnett $250
all parts from a black 2dr
may have other parts for 34 so ask if u need somthing
pm or text me on 0415 23 23 97, located in mansfield pk south australia.
Stripped my interior/boot and air con in the 32 (2dr). Have literally a pile of stuff here. Make an offer :)
Items:
All aircon gear, heater core, fans, under dash pieces. climate control unit, stereo side brackets, also back seats, a set of floor mats, boot trims, door cards, hicas, random bits.
Item Condition:
condition variable, most are good though
Contact Details:
sms - 0421666424
Price and price conditions:
make an offer on all parts, first in gets them, otherwise they're going in the bin
Edited by Sammy B
Items:
Item 1 - Front Strut Brace Cusco OS Type Suit R33
Item 2 - Standard RB25DET S2 Injectors On Rail
Item Condition:
Item 1 - Very Good Condition
Item 2 - Very Good Condition
Reason For Sale
Items No Longer Needed Bcoz Of Engine Build Up So Parts Have Been Upgraded To Suit New Setup PM For Pictures
Contact Details:
Call Or Sms Me On 0401409575
Item 1 - $120ono
Item 2 - $120ono
Edited by R334door(s2)
33GTR Gearbox
Mint Condition
To save the bullshit $800 FIRM
  • Therefore: no CRUNCHY CRUNCHY or GRINDY GRINDY!
  • Takes push type clutch
  • Not sure where shifter is
  • Includes front drive shaft free!
Pick up in Glynde 0413739644
hey guys im after a cheap track car to get started down there,
preferably a s13 or a 180, ca18det or sr20det. (maybe r31) but show me what ya got anyway
price range im looking at is 2k to 4k
car does not have to be road rego'd but id much prefer the car to be rego'd so i can get to work after i sell my car :D
cheers fellas! just throw us a hola n show me what ya got, cheers blokes
20 inch by 9" and 10" Moven GR5 staggered wheels and tyres, stretched tyres. Too wide for sedans.
Fronts are:
20x9, +40mm offset
Achilles 225-35-20 tyres (stretch fitment)
70% tread remaining
Rears are:
20x10, +20mm offset
Nexxen 245-35-20 tyres (stretch fitment)
50% tread remaining
These alloys have about 1 inch more dish than the fronts.
5x114.3 stud pattern, HAMANN centre caps
Cost $4000 brand new, want $1500 firm... or will consider swap for something similar looking with less offset (not interested in tempe bling or commodore style wheels thanks)
Edited by Trick V35
Got full set of stock rotors, still got fair bit of meat on them, front more so than rears and bendix ultimates to go all round also with meat left.
Good for track day backups etc.
$70 ono need them gone
Pm me
Pm me
what are they from? may be keen
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
