up for sale is my little bro's s15
P plate friendly jap spec s15 (non turbo)
just under 91 000kms
auto
everything completely stock besides the cannon muffler
will come with s15 stock rims
not realy much else to say about the car
PRICE $11800
any questions please pm me or text on 0415 23 23 97
car is located in mansfield pk S.A
my R33 Gtst is forsale, looking for $16 as is, ill add more pics to the main section when I get time.
price is negiotable depending on what state of tune it is in. Be nice to sell as is on E85, with a nice fat 350-380 rwkw.
Ill be running it at the dyno day if not sold before!
please pm or text/ring for more details.
0403302513
cheers
cleaning out the shed
r32 radiator with shroud and hoses $150
r32 clutch fan $50
r32 2 door taillights $60 pair
r32 a/c condensor $70
r32 a/c compresor $80
r32 gearbox mount $50
r32 clutch slave cylinder $40
r32 stock rear swaybar $10
r32 stock intercooler $20
r32 dash pretty good condition small bubble,was going to keep for my car but cant be botherd $50
r32 power steering pump hicas $40
r32 gtr ignitor $40
r33 drivers door with window silver $100
r33 gearbox mount $50
r33 standerd boost solinoid $40
r33 gearbox tailshaft yoke cut off $50
r33 manaul peadal set $40
r33 washer bottle $20
r33 stock intercooler $20
r33 rear cradle with all arms and hicas $150 or $25 a arm
r33 starter motor $50
r34 manaul pedal set $40
r34 a/c compressor $150
r34 5 bolt drive shafts $70 pair
s15/14 washer bottle $40
s15 front swaybar $50
s15 front crossmember $40
s15 drivers side splash sheild $50
s15 brake master cylinder abs $60
s14 sr stock intercooler $30
s14a front bar with indicators $100
s13 sr radiator with shroud and hoses $60
issota red steering wheel $50
blitz turbo timer $20
can mms pics located sa athol pk 0422030855
up for sale is a r33 gts rolling shell for drag/drift only has sunroof
no interior missing bonnet + front bar, lights
it has a few small digs on it nothing major
4 stud gts brake (not 5 as show)
asking for $400
text me on 0430606223
SOLD SOLD SOLD
R33 Genuine Hybrid FMIC (600x300x76) and Piping kit. Note that intercooler hot size pipe has a small gash/hole (about 1cm long by 2mm wide) and would require welding to fix prior to fitment, or you could clamp a silcone joiner over the gash. Price reflects this.
$250 - pickup from NE 'burbs.
Edited by Ionos
PRICE DROP ON MOST ITEMS
RB25det sump $30
R33 sr2 wing needs paint $30
GTR wing no end caps needs painting $160
R33 Air Conditioning Condenser gtst 1994 $35
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 climate control $35
R33 gtst fuse box and cover $20
R33 gtst sr1 bonnet hinge set $15
R33 gtst overflow and washer bottle $25 for both
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $55
R33 gtst battery tray need painting $10
R33 manual gear shift boot/plate $20
RB25 R33 GTST SR1 CAS CAM ANGLE SENSOR AND BRACKET $45
R33 clutch master cylinder $30
R33 RB25 skyline power steering reservoir with lines $20
RB25det fuel rail $20
RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20
R33 Air Conditioner Compressor with lines as seen in pic $55
RB25det sr1 aac valve $40
r33 gtst sr1 carbon bonnet $400
fiberglass vent (uncut vent) $55
rb25 turbo 45v2 has a blown seal $50
R33 gtst sr1 abs unit and bracket $60
R33 gtr intercooler (corrosion on bottom)$35
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 turbo oil drain pipe $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $90
r33 horns $10
r33 sr1 bonnet in primer has a few scratches and a small dint from sitting in the shed $120
catco high flow cat 2.5inch 325mm long $50
apex rb25 front pipe 2.5inch has a few dings $100
Nismo muffler 2.75mm inlet with 4.5inch tip $150 plus rear section that suits r33 free with muffler
PICS http://www.skylinesaustralia.com/forums/topic/364044-shed-clean-out/page__st__20
pm me or 0435888239
Will post at buyers expense
Dave
Complete stock rb25det
Includes the following:
Rb25det series 2 engine
Tomei adjustable exhaust cam pulley
Stock exhaust manifold and turbo
Dump front pipe
Cross over pipe
Intercooler & Pipes
Complete series 2 loom to suit
Series 2 ecu
Brand new bosch belts
Brand new water pump
post-31991-0-29761900-1309769029_thumb.jpg post-31991-0-93154400-1309769062_thumb.jpg
Had a slight bottom end noise when cold, ran really well starts first time, turbo is in new condition no shaft play
$1000 the lot or will separate
Edited by FOOLBOOST
Up for sale is my 1995 R33 Series 1.5 Mspec 5sp manual
Car makes 260rwkw on only 15psi, has the following mods:
Rb25det Series 2 engine
· 3" Stainless Mandrel Bent Magnaflow cat back exhaust
· 3" Dump front pipe
· 3" hi flow cat
· Twin 2.5” Stainless rolled tips
· Pod Filter
· Silicon hoses and lines
· Bosch 044 fuel pump
· Exeddy Gtr Cerametallic Clutch Kit
· Lightened Chromolly Fly wheel
· Pro-Stopper Series 5 Alarm
· Triplex Immobilizer
· Head Unit –Pioneer 50x4 DEHP5150USB CD/MS Receiver with MP3/ATRAC3 USB
· Pioneer 6" 4way 280watt fronts
· Kenwood 7x10's 350watts
· Nismo 400r Sideskirts
· Nismo Clear Side indicators
· Kenwood 600w Amplifier
· KYB Coil Overs
· 20% Tinted Windows
· Twin K&N oil breathers with fliters
· Custom engineered hicas lock system
· Nolathane bushes
· Z32 Air Flow Meter
· New Frount Mount intercooler
· New High flow turbo (Rb25det turbo 21U Hypergear highflow gt3076 core)
· New Remaped ECU
· Manual Boost controller
· 18x9" ROH Drift R wheels with near newYokohama Advan Semi slick 235/40/18 all round!
post-31991-0-65905000-1309828262_thumb.jpgpost-31991-0-25592500-1309828294_thumb.jpgpost-31991-0-60952700-1309828370_thumb.jpgpost-31991-0-56840200-1309828412_thumb.jpg
Is capable of 285-300rwkw with more boost, see attached dyno charts, car is stealth under the bonnet as to not attract the wrong sort of attention.
Very fast street car not for the faint hearted, would do excellent track / quater mile times too. Great for street daily driving or tracking when you want to have some fun
Car starts first time every time, is in excellent condition as per pics, reason for sale is have purchased a track car.
Note wheels not included(avaliable for purchase), will come stock r33 ones
13k
Pm with enquires
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
