r33 s2 gts4 shell with all runnig gear and suspension and brakes, missing panels and interior (has dash n ssterring wheel and all glass), manual. Just begging for an rb30 bottom end. PM for more details. $2k ono.
Edited by KISIN
r33 s2 side skirts, in primer, couple small fixable cracks - $50
rb25 s1 afm - $50
r33 s1 indicators - $20 no globes
r33 swaybars front + rear $10ea
located in marion area
pm or sms/call 0422 314 938
hi there just cleaning out the shed and found my old wing for my s14, no need for it nomore got no car so its up for sale.condition is good. price is 250 ono
also i have a r32 welded diff for sale for 120 = sold
and i've got a subaru wrx 2000 model stock air intake where it goes near the wheel arch for 20 bux
please contact 0422164665
full r32 4door interior, mint, grey colour, $50 - will be going to dump wed.
r32 centre dash vent - $50
r32 climate control unit - $20
r32 blue faced dash cluster (170,000) - $50
do have other things will update later..
txt me on 0433 290 801 for pics.
Neo AFM - $50
C34 stagea lhs front fender - $100
6 coilpacks, condition unknown - $50
Neo engine cover - $50
RB25DET valley/coilpack cover - $25
PM me
hey ruby, i'll grab that neo AFM off ya, i think mine may be having some issues???
PM sent
Neo AFM - $50 - SOLD pending payment
6 coilpacks, condition unknown - $50 - SOLD pending payment
RB25DET valley/coilpack cover - $25 - SOLD pending payment
PM me
Series 3 V-Spec GTR
http://www.skylinesa...33-gt-r-v-spec/
Series 1 gtst 276 on 16 psi
http://www.skylinesa...-skyline-gts-t/
are you sure its a series 3? has a smaller front lip than mine
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
