L&RH DOOR LATCH INSERTS $ 15
mint 180sx door trims
centre console with mirror controlls
2X REAR SEATBELT LATCHES $10
HANDBRAKE COVER $15
1X RANDOM SMALL VENT $5
FUSEBOX COVER - SLIGHT HOLE $5
LEFT FOOT REST $5
1X FUSE OVER $10
FLEXI GEAR BOOT $10
L&RH MIRRORS - DRIVERS SIDE MISSING GLASS
DRIVERS PLASTIC DOOR MOULD
2 SETS 180SX TAILLIGHT GARNISHES
L&RH WIPERS
1X GEARBOX MOUNT steel minus rubber $40
BLACK GOOD PAINT DRIVERS DOOR 150 (incl glass latch and power motor)
BRAKE BOSSTER
L&RH PILLAR TRIM
MINT WHITE REAR HATCH $150
PASSANGER 180SX REAR WINDOW
REAR CAMBER ARMS $50
CA LOOM
MINT BONNET WHITE $160
GEARBOX HARD CHASSIR RUBBER COVER
CHAROOL CANISTER
L&RH TOP FRONT SEAT TRIM
UPPER DOOR PLASTIC INTIRIOUR MOULDS
L&RH SIDE PEAR LOWER TRIM
GOOD SHELL STRAIGHT FROM FRONT SHOCK MOUNTS BACK can be sold with front cut t use for repair $400 with the front cut
bare 180 front cut minta totaly bar 150
R34
POWERSTEARING PUMP $80
AUTO CONVERTER $50
AUTO STARTER MOTER $80
R32
4 door bn kit brand new minus front bar $250
2 door bn sideskirts good nic $100
R33 STEARING COLLUM
BUMP!!!!!
R33 stock air box and snorkel with near new apexi pannel filter $70
By joey_5004 at 2011-07-14
r33 stock coolah with all pipes $50
r33 sers2 rear seat set in mint con $50
r34 set of GT-T rims with out tyres $170
r33 stock front shocks and stock rear springs$50
r33 aftermarket front bar, needs paint. has afew cracks and is missing the left hand side cover over the fog light $150
R33 seris2 front grill in silver.. has a clip or 2 missing and afew scratches $50
Pm or 0431528958 ..
BUMP !! everything needs to go .
1: R32 "A" Piller mounted boost guage trim to suit 60mm guage $10ono - Pending payment
2: HKS Boost guage and loom (60mm) $40ono - Pending payment
3: Steel Mate 386M Remote Central Locking System (No Actuators came with kit) $40ono
4: 2x 5 stud 15mm Hubcentric Bolt On Spacers $100 FIRM - Need to sell spacers ASAP - SOLD
5: R32 2door L&R boot trim $5 each (Has holes cut out for strut brace)
Or take Boost guage and piller for $50.
Central locking kit was bought for my Daily but never got round to instaling it (Has never been used)
Boost guage will NOT come with vaccum pipe due to it being used for another guage.
Items:
Hankook RS3 265x35R18 (x4).
Item Condition:
Brand New.
Extra Info:
Surplus from Superlap, and I don't own any 18s to use them myself post event. Locally approximately $395 per tyre. Very impressed with the grip of these tyres on a racetrack. Fantastic high performance street tyre. These are the tyres you want for Superlap clubsprint class. Available now.
Contact Details:
Via PM is fine.
Price and price conditions:
$1,200 FIRM. Pickup - Cash, EFT, etc.
Now with a picture!
have 4 18'' lenso wide track rims for sale 2 in perfect condition 2 need to be re rolled due too buying them already like that, comes with 4 tires in near new condition if i remember correctly. just sittin in the garage $200
Edited by gilly_ECR33
Could you pm me width offset tyres etc with pics
For Sale following items which i purchased but never got around to installing. Due to defects I have changed my mind on what i want to do with the car so this stuff needs to go.
Sard 600cc injectors $500
Greddy cam gears to suit RB26(new) $400
Sard FPR $80
Tomei Type A poncams $600 inc postage These are for BNR32/BCNR33 (RB26DETT).
A252X A269IN lift in ex 9:15
Apexi Power FC with hand controller (suit R32/R33 RB26DETT) 1000$
For sale.
R33 S1 Dash 100$ - Has 3 screw holes on the passenger side as seen in picture.
10 000k HID Kit - Used for a few months but working fine - 50$ (Blue light)
Cusco Strut Brace - Type OS (New but with some scratches) - 100$
hey i have a silver 4door shell.
the shell is pretty bare, not much inside worth using, lhs side doors are mint, 3 out of 4 door trims mint, handbrake cables (all 3) are there, rear subframe and all rear setup is there minus diff and rear steering arms.
no boot, rear bar, rear lights.
you can make some $$ off the handbrake setup and rear brakes and the rear subframe/rear shocks.
has rego 2months
needs to be gone this weekend...
$500
has rego 2months
$500
When can I grab the handbrake handle off of you?
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
