Sr package,
over 200atw, remap, t28bb, braided lines, solid intake
tight 5speed, with carbon drift clutch
$3500 ( can see running )
Hybrid Fmic Kit
$400
Teins with cusco tops
$700 ride hard as, no noises
Cusco rear strut brace
$120
Whiteline Fr Brace[/b
$100
Clear tailights, ( neva seen same ones in S.a )
$250
Rolling shell, with new paint, front bar bit f**ked $1500
Profec B
$250
17x7 rims with small dish 5 of
$500
pics of car should be a page back
any more pics or info txt on 0407 627 431
hey guys,
help me get to track day!
R32 GTS GTR carbon Nismo Trunk Spoiler - 200
R32 GTS GTR carbon air Deflector - $165
0433 290 801
Pics of spoiler please, txt them to me.
For sale
R32 jasma catback 3.5" with cannon 150$
R32 front reo not cut 100$
Front drivers seat mint 100$
Pair of 34 stockies 17x7.5 shresdes Tyres 100$
Set of territories 17x8 good offset 350$
Stripping r32 so just ask.
Open to offers
Contact 0435163144
FOR SALE
Haines Hunter 1800S Ski Boat
Powered by Evinrude 175 VRO power tilt and trim
Includes intermediate prop on moter,Raker Prop and spare standard prop
New plugs and stainless steel leads
New VRO Unit and Igniter coil
New heavy duty calcium battery
On fully galvanised trailer fitted with self guiding rollers
New light truck tyres and spare
5 Safety vests
2 Fire extinguishers
Radio and speakers
Fitted with 60lt stainless steel bow tank and 70lt stainless steel centre tank
Sky pole and rigging (6ft Ski pole)
Full storm cover
Very quick boat (can do 110kph on glassy water)
Allways kept under cover and very well looked after,regretful sale but no longer used and its taking up space.
Pics available on request via email.
Phone Cliff 0413 059 611
Email [email protected]
$11500 ono
Edited by funki_munki
R33 set of stock struts with aftermarket rs*r springs great for street $200
R33 rear seats $200
R33 centre console $50
Titanium 3 inch rear muffler sounds and looks unreal $200
Stock rb25 dump/ front pipe $50
R33 a/c parts inc. Motor, pulley, engine block bracket, condensor, lines ect $100 for the lot
Stock r33 front camber arms $50
R33 wiper bottle $30
9mm neck pod filter $5
R33 centre roof light $30
Hks mushroom style pod filter brand new still in box $50
0417084638
r33 front braided brake lines $60
r33 series 1 grill $50
r33 rb25 series 2 engine loom $60
r33 coupe driver side window switch surround in CF wrap $15
r33 series 2 coupe driver side window switch $30
today only otherwise its going in the skip.
This car was going to be built as a daily driver but the owner has new plans now. car is ALMOST finished. just needs an exahsut and interior put back together. apart from that everything else is done! Car is currently unreg and will be sold as such but has papers and legit plates to re rego it. Has never been defected!
Specs:
  • KE70 flat front
  • ORIGINAL 98,000 kms on the car. Chassis is 100% rust free, interior while currently dusty in photos is in very good condition. has factory log books, rear blinds, and the paint just needs a buff.
  • S13 spec SR20det with brand new Extreme clutch,
  • Full S13 running gear with crossmember, steering shaft, power steering, etc.
  • Brand new HSD's in the front, never been driven on
  • FMIC and custom pipe work
  • Custom wiring loom, car is all running!
  • massive cooling system
  • Custom tailshaft
  • R31 complete rear diff conversion done
  • Fuel system in boot with surge tank and Bosch pump
Pics below tell the story. yes it is dusty and needs a clean up. has just been pulled out the shed. the car will be sold as an unfinished project but as mentioned above all that needs doing is an exhaust and then your set.
Price: $8000 ono
Contact Info:
Car is viewable at All Type Crash at 1395 Main North Road, Para Hills West during business hours. or you can contact Allan At All type Crash on (08) 8281 0130
For Sale
R32 GTS GTR carbon Nismo Trunk Spoiler - 200 x2
R32 GTS GTR carbon weather shields - $165 x1
RB26 valley and timing cover in carbon - $140 each or both for $250 x1
RB25/RB20 valley and timing cover in carbon - $130 each or both for $240 x1
R32 GTS/GTR carbon headlight duct - $190 x1
R32 vertex front and rear bar (2door rear bar) - $220 each or both for $400
R32 25mm vented front guards - $220
all items are brand new!
can post aust wide at buyers expense
0433 290 801
Hey guys got a AMPerformance dumpipe/frontpipe for sale came off my R33
$150.00
and x4 michelin pilot sport 245/40zr 19. 70-80% around 4-5mm above wear bar on 2 and about 3-4 on the other 2
$200.00
Located Parafield Gardens
Edited by Marky88
Nismo Front Camber Arms to suit R32
bushes are in good condition, The bushes in these are stiffer than standard
Non Adjustable type. , some of silver paint is coming off.
quick sale $70 NOW $50 >>>>will freight Aust wide (extra)
S13 SR20DET Gearbox
good condition
with shifter
$550
HKS Electronic Boost controller EVC 4
all looms and valve
$180 NOW $140>>>>will freight Aust wide (extra)
RB20 engine mounts rubber $20
Call or sms only no pm
can pick up Tee Tree Gully area
Paul 0422444532
Edited by DR30RSX
$150.00
$200.00
Dumpipe/frontpipe sold pending payment
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
