Well it's come time to sell my Stagea
Its a june 2000 Build C34 Nissan Stagea, 93,000km and still has a couple of years left on its warranty
It has the Full Dayz bodykit including the carbon insert in the front bar, carbon mirror covers, carbon "d" pillar covers and taillight covers
Engine is still the standard RB25DET Neo, running standard boost control and just a Blitz pod filter
It has a 3" bellmouth Dump pipe, 100cell Stainless highflow cat and a full 3" system finishing in twin 3.5" tips
Auto trans has been fitted with a shift improver kit by MV autos and had a full service and attesa bleed
The tiptronic shift on the MOMO steering wheel is awesome
Rolling on 18 x 9.5 +20 Enkei rims with brand new tyres, Whitlen adjustable rear sway bar and R33 GTR dampner adjustable front shocks
Fitted with a 1250kg towbar it bulls my boat with ease. Great family car, fun car thats practical but still surprises some at the lights
$15,499 ono
I can remove items to make it cheaper, I still have all the standard parts in the shed (ie rims, sway bar, quiet exhaust, compliance cat, shocks,etc)
Pm me for further info
  • Like 1
Hi guys. Thinking about selling my Nissan Stagea to get a 4wd with a larger towing capacity. I will consider SWAPS for a 4wd, after a dual cab as a minimum so dont tell me about your utes or commodores/falcons. Prefer a Cash sale
  • -Nissan Series 2 RS4 Stagea - Snow Edition with lockable centre diff
  • -Tiptronic auto
  • -140K kms
  • -Neo Rb25det, had factory nissan 100K service done by Nissan. all new belts, pumps etc etc, very well looked after and maintained
  • -New CV's fitted to the front both left and right
  • -R33 Brake upgrade.. stops way better then a stock stagea.
  • -wheel alignment done last week
  • -Dayz sideskirts and rear wing fitted
  • -Bleed valve and boost gauge, running 11psi. goes very well
  • -D&T exhaust system - have reciepts
  • -Tow bar fitted. have towed my race car + trailer + full car of people + fuel and tools + tyre rack with no drama's does it very well
  • -Tein Wagon Master coilovers. near new, have the reciepts, manuals and adjusters for them. handles great!
  • -18inch Speedy wheels all round with Federal 595's up front and neutons on the rear. plenty tread left
  • -3 months rego
  • -Pioneer MP3 player with a full set of awesome speakers/splits. sounds great without being over the top
  • -ALL electrics work
  • -inside and outside is immacualte!
  • -Recently fitted a triple point alarm/immob which complies with Aust standards and insurance worth $700
  • -have a stack of reciepts for the various work done
Price - 11K ono or swaps as above in bold.
Pm me or call/sms me for info. 0412 938 933
Some pics.
For Sale: 2x 25mm Bolt On Hubcentric spacers with all nuts $100 Firm
I'll take them if they are 5x114.3. I can pick up on sat when i'm in Adelaide, tho may be able to get my 'rents to pick up earlier if required
For sale from R33 S2
- Silver rear wing - $200
- Side mount intercooler with elbow pipe - $30 ono??
- R33 S2 ECU - $100
- Greddy turbo timer - $30
PM for details
Need this stuff gone asap, make an offer
pair of 27mm spacers $100 firm skyline 5 stud pattern.
R33 Genuine GTR grill in white $250
R33 fibreglass grill white $100
r32 4door skirts an pods plastic, brand new never fitted $600 set
rb20 cas $50
R33 brand new clear side nissmo indicators $100
Fuel setup new, Bosch 910, bracket and swirl $300
R33 tailights black $50
Edited by PROXIMITY
Bride racing reclinable seat for sale,no rips and no fading so still that nice dark colour - $850 neg with rails suit s13/14/15 r32/33 need it gone this week
Contact via SMS 0401475561
Cheers sam
THIS NEEDS TO GO $750 AND IT'S YOURS!!!!!
MSD digital rpm window switch.
used to control things like VCT, thermos, water spray or anything else you want to turn on and off at desired rpm.
this unit is all digital so press a button to set the rpm in 100rpm increments.
its pretty much brand new with box and instructions.
$100 (cheap)
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
