R33 King Springs (Unsure if they are Lows or super lows)
Serial numbers if you want to search it KDFL-101 & KDRL-61 - $100
Stock RB25 Dump pipe - $20
Stock R33 Side Mount Intercooler - $20
MOMO Steering wheel, flat bottom style. Old but ok condish can MMS a pic - $20
SMS 0401 227 678 - NO PM'S
1. Pair of Enkie 16x7 4x114.3 +38 - clear 4-pot brakes (suit silvia, r31 etc) -$200
2. Pair of 31 stockies, good tread on one, none on the other -$50
3. Pair of dirty 17x7 skid rims 4x114.3 offset unknown (suit 31, silvia) Tyres good on one, poor on other -$50
4. Silvia radio surround thing, 2 holes for gauge mount -$10
5. stock SR20det turbo dump -$50
6. Stock s13 brake calipers (and rotors for free if you buy the calipers) -$25
7. Stock s13 brake master -$20
8. Random bit of polished pipe -$5
9. SAAS steering wheel -$20
10. BOSS 4-channel amp 800w -$50
11. Kenwood 1000w monoblock amp for your sub -$150
Pics on request
All items located North East of Adelaide near TTG
contact
0402 035 914
or by pm
FOR SALE Full F&R R33 GTS-T Bilsteins with whiteline springs. Come assembled with tops, Extra circlip grooves for height adjustment, Purchased at the tail end of the Sydneykid groupbuy, approx 10-15k kms.
perfect condition, hard to find a better sporty street shock. $750 ono.
pics of rears, fronts also perfect.
FOR SALE Full F&R R33-R34 GTR HSD coils. Fully adjustable, perfect conditon, approx 5-10k kms travelled. $800 ono
http://www.otomoto.com.au/p/4149192/hsd-hr-type-coilovers-for-nissan-skyline-gt-r-bnr34.html
post-34685-0-14064200-1319512446_thumb.jpgpost-34685-0-68122100-1319512472_thumb.jpgpost-34685-0-48401600-1319512536_thumb.jpg
pm or ring 0468353923
cheers
FS All my spare parts
All offer welcome need to move it all out of the shed Asap
R32 bn rear bar 2 door Slight repairs $50
R32 rear bar 4 door BRand new 150
R32 4 door bn skirts brand new $150
32 front cut bare $200 (For Repairs)
32 4 door rear quater $250
R32 gtr rear brakes $350
R32 gtr rear diff and shalfs $400
r32 gtr stock struts good nic $200
Gtr front cradle $ 300
Door Trimsx4 $350
Rear seats $150
Carpet $50
Climate $50
cluster $100
Doorsx4 100 ech
Boot $150
Rear bar 180
Tailights $200
gtr rear cradle complete minus brakes $400
Rb stainless manifold $100
fs rb20det awd motor with auto trans willing to seperate $1500
r32 gts4 rolling shell $2200
R34 power stering pump 100
R34 auto converter and starter motor $50
Mint 180sx door trims.$100
centre dash console $30
some small random carpet bits
L&RH DOOR LATCH INSERTS $ 15
2X REAR SEATBELT LATCHES $10
HANDBRAKE COVER $15
1X RANDOM SMALL VENT $5
FUSEBOX COVER - SLIGHT HOLE $5
LEFT FOOT REST $5
1X FUSE OVER $10
FLEXI GEAR BOOT $10
L&RH MIRRORS - DRIVERS SIDE MISSING GLASS
DRIVERS PLASTIC DOOR MOULD
2 SETS 180SX TAILLIGHT GARNISHES
L&RH WIPERS
1X GEARBOX MOUNT steel minus rubber $40
BLACK GOOD PAINT DRIVERS DOOR 150 (incl glass latch and power motor)
BRAKE BOSSTER
L&RH PILLAR TRIM
MINT WHITE REAR HATCH $150
PASSANGER 180SX REAR WINDOW
REAR CAMBER ARMS $50
CA LOOM
MINT BONNET WHITE $160
GEARBOX HARD CHASSIR RUBBER COVER
CHAROOL CANISTER
L&RH TOP FRONT SEAT TRIM
UPPER DOOR PLASTIC INTIRIOUR MOULDS
L&RH SIDE PEAR LOWER TRIM
GOOD SHELL STRAIGHT FROM FRONT SHOCK MOUNTS BACK can be sold with front cut t use for repair $200 with the front cut
180sx sunroof cut
Items:
R34 standard intercooler
front shocks and springs to suit r33
Item Condition:
Cooler in good condition
Shocks second hand, but springs brand new king springs. Low or super low, cant remember, but was enough to get through regency inspection and look low.
Contact Details:
Prob best to email or text message, [email protected], 0435183200.
Price and price conditions:
intercooler- $100
Shocks and springs- $100
FS
Early R32 GTR Gearbox, no idea of KM's on clock but would assume around the 100,000km I assume my chassis has done
Gearbox only - no transfer case, is dirty as sin and needs new synchros but the gears are in good nick
Good for RWD applications that need a strong box
$500 ono pick up - delivery extra
-D
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
