Got some stuff sitting here doing nothing:
3inch cannon, unsure what brand, no dents or huge scratches but used not new. $40
Twin 3" straight pipes, 3" inlet also.
Bought for $120 a month or so ago and ended up with a stainless exhaust, so price is $120 firm.
N1 GTR spoiler "Carbon fibre look"
Cost me $300+ postage off Just Jap. Save on postage $300 pick up, Brand new!
http://justjap.com/store/product.php?productid=17338&cat=&page=2
2X 235/45/R17 Federal 595-SS, above wear indicator still good for a few skids $80 for both
Kicker 'comp' Sub & Amp. $300
Kicker Sub and Amp comes with all wiring and everything you need to hook it all straight up, sounded really good when I had it in the other car, has a proper Kicker ported box and all Kicker wiring also.
Selling for $330 at JBs (without full wiring kit, fuses etc I'll give you with it!)
http://www.jbhifi.com.au/car-sound-gps-navigation/sub-woofers/kicker/amp-sub-box-combo-sku-73622/
Was only used for around 6 months!
Pics:
[/quote
Bump!
R34 Parts For Sale:
Pink Label AFM - Perfect working order $50
R34 Airbox & Snorkel with a ryco panel filter $50
RB25det Neo Coil Packs - Perfect working order $80
Stock Cat - $50
Rubber Intake Pipe - $20
Stock Fuel Pump - Perfect working order $30
Front Seats - Will sell as pair only $200
Generic Parts:
Slip on spacers 8 or 10mm $10
1 din triple gauge mount $10
HKS Turbo Timer $25
Samsung Omnia Icon 2 I8000T Mobile with ac charger $120
Parts all located in Clearview (near Gepps Cross Int).
All Prices are ONO so make a offer,low balls will be ignored.
Pics/inspections available on request.
Contact:
PM on here
or
0432 838 323
Daniel
Edited by funki_munki
s2 rb25 (not neo) splitfires with braket and loom - $sold
r34 GTT front brakes inc: calipers, rotors (dba4000 slotted), pads (a1rm). rotors and pads under 500kms old - $600
eboost boost controller with solenoid, wiring and vac hose - $300
99% brand new r32 gtst BC br coilovers - $1000
1.5L surgetank ($150), 044 pump ($200), magnaflow fuel filter ($150), lines and fittings - $sold
r32 early style brick headlights (n1 looking without the brakets for n1 vent) with globes and wiring - $150
pm and i can txt pictures.
Blitz Nur Spec exhaust 3" stainless cat back to suit r33 comes with 3" cat $350
Tow bar to suit s2 stagea, comes with wiring plug and fittings $250
s2 stagea auto centre console $70
s1 sagea auto trans with MV automatics shift kit $400
AVS wheels 17x8 and 17x9 with 235/40 all round heaps of tread left $450
s2 rb25 550cc injectors in standard rail $350
Still for sale:
Sorry some of the pictures are as links, wasnt letting me post pictures properly.
New N Spec water pump (R33 GTR) - 200$ (Top in the picture - Unsure if it suits other models apart from R33 GTR) - Brand New in box
New East Bear clear front indicators (R33) - 150$ - Brand New in box
Indicators 1
Indicators 2
More info on indicators here
http://www.nengun.co...stal-indicators
Greedy Oil Catch Can - 150$ (Used for 1 month - comes with original packaging etc)
More info on catch can here
http://www.streettun...-/prod_342.html
Isotta Steering wheel Perfect Condition - with Boss Kit (came off Silvia) - 80$
Steering Wheel
Can call/text on 0408 370 576 - Pickup from Hindmarsh / CBD
R34 Parts For Sale:
Pink Label AFM - Perfect working order $50 SOLD
R34 Airbox & Snorkel with a ryco panel filter $50 SOLD
Stock Cat - $50
Generic Parts:
HKS Turbo Timer $25
Contact:
PM on here
or
0432 838 323
Daniel
R34 Parts For Sale:
Stock Cat - $50
Generic Parts:
HKS Turbo Timer $25
Contact:
PM on here
or
0432 838 323
Daniel
Pic of the left over items. Just a note,the seats are from a sedan not a coupe,pics of these shortly.
R32 GTR front seats - including adaptor for drivers seat to fit 180SX etc (can still fit R32 GTR) $600ono good condition
R32GTR Jap tuned factory computer - no speed limiter / boost cut lifted. Made 270rwkw with STD turbos at 21psi....perfect for the Garrett dash upgrade turbos! $300ono
5 Point Safety 21 Roll Cage (Half Cage) for R32 GTR / GTST. Blue padding, includes mounting bolts. $700
Bump it up!
