Heya guys,
Set of stitch evolution wheels, theyre 5x114.3 17x8 or 17x8.5 i dont remember exactly but +8 offset all round
Bit of gutter rash, nothing serious, 2 good Dunlops up front, rears goneski.
$650 ono, need em gone now.
also
R34 GTR Ohlins coilovers in near new condition. $1100, these retail at $4000.
0422 314 938 or pm
r32 radiator and hoses $80
r32 clutch fan $50
r32 2 door taillights $50 pair
r32 clutch slave cylinder $20
r32 stock rear swaybar $10
r32 dash pretty good condition small bubble,was going to keep for my car but cant be botherd $50
r32 gtr ignition ignitor $30
r32 rear cradle with all arms $100 or $20 a arrm
r33 drivers door with window silver $100
r33 standerd boost solinoid $40
r33 manaul peadal set $40
r33 washer bottle $20
r33 stock intercooler $20
r33 rear cradle with all arms and hicas $100 or $20 a arm
r33 starter motor $50
r34 a/c compressor $150
r34 5 bolt drive shafts $50 pair
r34 manaul tail shaft $100
r34 turbo 0p6 rear housing $450 mint
s15/14 washer bottle $30
s15 front swaybar $40
s15 front crossmember $25
s15 drivers side splash sheild $40
s15 brake master cylinder abs $50
s14 sr stock intercooler $20
s14 s1 rear spoiler red $20
s13 sr radiator $50
intercooler core 600*400*76 $100
apexi n1 cannon muffler $150 paid 600 awhile back
issota red steering wheel $50
blitz turbo timer $20
r34 gtr rims freshly resprayed in ppg paint they never been buckeld or repaired other than paint
i wouldint be selling them if i didint have bills....
no center caps or tyres $1800
Set of stock s15 wheels few grazes on them tyres good for a few skids $300 ono
also have a s15 shell has front end rail damage offers $$$
can mms pics located adelaide athol pk 0422030855
Nintendo Wii, hardly used, includes all required cables and sensor bar. One small scratch on the right side of the console.
2 controllers
Super mario Wii
Wii Sports
Pikmin
Links crossbow training with gun
My Sims
Donkey kong jungle beats (no bongos)
Wii Fit (No board)
All discs are perfect.
$160
Located Greenacres adelaide
SMS Sam on 0421 460 040
Edited by awsam
Can send larger items interstate as long as the buyer helps arrange courier... if you have preferences etc...
WORK VSKF
Black with chrome lip
Good condition
Can come with or with out tyres
18x10 +7
18x10.5 -23
$2700 ONO No tyres
$3000 ONO with some decent tyres
Attached Image: IMG_0656.JPG Attached Image: IMG_0658.JPG
Can send if buyers helps arrange courier.
Work EMO CR KAI
17x9 +17
18X9.5 +12
Gunmetal colour
Rash on all rims... used as skid rims on the drifter
$1200 with tyres......Tyres are so so
Tial MVS 38mm external gate V BAND connections INCLUDING stainless screamer
Has water cooling ports
New compact design, also has extra springs (5 all up). Currently has the 10psi spring installed
Comes in the box, extra springs all clamps and fittings etc
In AS NEW condition as been used about a dozen times on the dyno then decided I had to go larger..
INCLUDES SCREAMER PIPE
$270 FIRM...
Tune Agent Rear Camber Arms
suit s13/180sx
Good condition
$100
Tune Agent Rear Toe Arms
Suit s13/180sx
one side had a small crack near the bracket. Has been re-welded and no drama
$60
Tein He Coilovers SUIT S13/180sx
8k front 6k rear
2way height adjustable
Damper adjustable
No leaks, knocks etc
Selling due to upgrade
$1150 ono
Greddy/Trust copy sump
Need a new thread tapped into the sump plug hole as the last "mechanic" to work on it f*cked it. Imperial bolt into a metric wont go...
$80 ono
Emanage Blue - no harness, a few minor scratches - $200 ono
Software and cable to suit Emanage Blue - $50 ono (Was $100 to buy)
Emanage Ultimate Harness, N9 - Suit early SR I think - never used, still in bag, could dissasemble to use with emanage Blue - $100 ono
R33 gtst sr1 front gaurds in great condition (Rolled lipped) $140 pair
R33 gtst sr1 2door bare doors with door handels $50 each in great condition
R33 gtst sr1 2door front door glass $40 each
R33 gtst rear window $40
RB25det sump $30
R33 sr2 wing needs paint $30
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 bonnet hinge set $15
R33 RB25 skyline power steering reservoir with lines $20
RB25det sr1 aac valve $40
fiberglass vent (uncut vent) $50
R33 gtst sr1 abs unit and bracket $50
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 turbo oil drain pipe $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $50 was removed the correct ay
r33 horns $10
Nismo muffler 2.75mm inlet with 4.5inch tip $70 plus rear section that suits r33 free with muffler
RB hard oil turbo line $25 (not sure if its rb20 or rb25)
RB hard water turbo line 1 $25 rb20 rb25?
RB turbo hard water line 2 $25 rb20 rb25?
R33 gtst window wiper set $ 15
R33 gtst sr1 passenger side electric window switch and loom $45
R33 gtst sr1 2door seat belts complete $50
R33 gtst sr1 air con units that sit behind the dash, heater cores $50
RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20
vr v6 commodore sedan fuel sender and pump(pulled from running) $40
r33 boot latch with plug $20
R33 boot and fuel lever $15
R31 1989 oz spec bonnet latch and lever $10
R33 a/c receiver,drier sensor $30
rb25det fuel modulator with bracket$25
R33 rear window $40
R33 stereo brackets $20
R33 sr1 dash trim(needs a clean and paint) $40
R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25
r33 sr1 bonnet in primer$80 has a small dent(can send pics)
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $40
R33 gtst false rear wall $20
RB25det stock dump on black vht $20
R33 gtst rear bar, will need small repair $25
r33 gtst sr1 power window motor regulator passenger side $60
R33 gtst rb25det hicas computer $50
R33 bonnet in black primer has a small bend in lip $50( can get pic)
R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $20
Rb25det sr1 cas with bracket $50
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50
Bosch 044 fuel pump BRAND NEW $180
I have r33 interiour parts, pm for what you after
pm me or sms 0435 888 239
Will post at buyers expense
Dave
R33 Gutted stock cat - $50
R33 Front discs - $50 (could do with machining)
Pair of 5 stud hubs, knuckles ,etc. Not sure what vehicle they are off but was told they were suitable for use in a 33 5 stud conversion, a couple of the studs are damaged - $150 for the pair!
Please PM enquiries.
post-63773-0-57415800-1323487215_thumb.jpg post-63773-0-60773600-1323487224_thumb.jpg
Knuckles SOLD pending payment!
Items:
Samsung 2233SW LCD monitor
Item Condition:
Very Good its a LCD monitor not a footy
Extra Info:
Will be ready for pickup or drop off next week
Contact Details:
txt or PM
0421932750
Price and price conditions:
$165 ono
Samsung 21.5" 2233SW+ Widescreen LCD Monitor - High Gloss Black, Full HD 1920 x 1080p, DVI, 5ms Response, 50,000:1 Contrast (DCR)
pickup/drop off Friday
Price Drop $110
All black D1r rims like new , 2 drift pracs old . Sold my drift car no longer required .. 17x10+15 - 17x9+17 ! 60% tread up front on bridgestone petenzas . Rears have camber worn west lakes but will supply a brand new set of tyres for the rear included I'n the price
Can send pics on request
0431528958
$1300
Dba 4000 slotted front and rear rotors for r33 gtst
QFM a1rm pads 1 new set 1 about 50-70%
braided front lines
Removed for upgrade before tracking car
$600
Trust? Style front bar for gtst white in color
$200 or with carbon canards $250
Removed as gtr bar fitted
Gtst aftermarket grill white $80
got an r33 s1 GTR steering wheel with airbag. 100 bucks
got a h1 HID 6000K kit, paid 200 for it, chasing 125
got a pod filter with adapter plate to suit rb25 want 30 bucks
got a hks evc4 chasing 100 bucks
got a blitz sbc, not current modle, chasin 100 also.
got a GFB BOV adjustable between atmo and plumb buck or a mixture of both, suits s14/s15 250 firm.
contact via email; [email protected]
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
