R33 side feed nismo 550cc injectors (yellow) 5000kms old
They come complete in the rail ready to go straight in
They are still in my car and will remove them when sold
Only selling to upgrade to e85
$500
Brand new r33 GTR jun style carbon front lip
$360 firm
17inch buddy club p1 racing originals in hyper gold
Mint con, tyres just about all had it
Nissan 5 stud patten
Unsure on width and offset will update soon
If your interested just text me and I'll go check
$750
0407083177 - Joey
Edited by joeyy
Got a heap of parts to get rid of. Moving at the end of the month and want to get rid of as much of it as possible. Make a decent offer and it's urs
S13/180SX - STOCK
stock front pipe
stock dump pipe with oxy sensor
4 stud hubs with good bearings
sr turbo front brakes with disks and pads
Hicas power steering resivour with level sensor
Hicas subframe with all Hicas lines, senders, lower control arms, disks & knuckles
AC condensor with lines
AC compressor with idler and brackets
R180 diff (suit 5x1 half shafts)
half shafts (5x1)
interior fan and heater core
AC interor core
hicas PS pump
T25 turbo on standard manifold
clutch fan shroud
stock intercooler with piping & BOV
charcol canister
standard suspension arms
most interior parts available
AFTERMARKET
Blitz aluminium mandrel bent piping to suit front mount
3" front dump pipe (mandrel bent, mild steel) with oxy sensor
C34 STAGEA
wrecking a c34 stagea (no gbx, motor), if any parts u want aren't listed let me know as i probably have it
nismo front suspension (springs & shocks, not height adjustable)
standard rear suspension (springs & shocks)
interor fan with heater core
AC interior core
front seats
door shells
rear hatch shell
roof rack
dash
carpet (minus hatch area)
headliner
visors
rear seats (top section only)
steering wheel (with radio controls) no centre
auto shifter
wiper and indicator stalk assemblies
front & rear seat belts
front AWD knuckles with 5 stud hubs
ABS unit
front X-member
rad overflow bottle (good condition)
UNIVERSAL
5x114.3 space saver spares
floor mats
4x114.3 space saver spares
4x 17"x7.5ish ROH adrenalin rims without tyres (4x114.3). can get specific offset/width if required. Can be freshly sprayed (rattle can) if needed
4x 17"X7.5ish speedy rims with pretty much gone tyres, one rim damaged (probs beyond repair). 4x114.3. can get specific offset/width if required.
Also have an NA R33 manual with full kit and a MQ patrol diesel 4 speed man for sale, soon to be posted
ph. 0407971706
Whats going on fellas, been a while since I've pocked my head around these neck of the woods...
Got my drifter up for sale.
Im selling up for a clean streeter as I get my full license back November :).
ENGINE:
JZS147 2JZGTE approx 110xxxkms
Cast single turbo manifold T4 flange 38mm wastegate
GT3582 anti surge turbo .82 ATP rear housing T4 flange
Custom oil + coolant turbo braided lines
JZA80 water pump
Re-routed wiring looms + bonnet cable to engine bay
GKtech plastic overflow bottle
Walbro GSS442 high pressure fuel pump
Removed throttle body traction control
Light weight drive pulleys
Sard radiator (S14) + custom piping
Front mount intercooler 450x300x76 + custom piping
HKS oil cooler core
Oil filter relocation kit + custom lines + Speedflow fittings
Oil catch can
Modified rocker covers with Speedflow fittings
Tial 38mm external wastegate
Bee R rev limiter
HKS FCD
3" custom exhaust turbo back 1 muffler
Custom accelerator cable
Radiator shroud with 2x 12” thermos
Turbo heat blanket
POWER: 299RWKW, 840NM @ 17PSI
DRIVETRAIN:
R33 RB25 gearbox
Cut and shut RB>2JZ bellhousing
Billet flywheel (W58)
single carbotic 5-puk clutch (RB25)
1300KG pressure plate (W58)
Custom 1 piece 3" tailshaft
Welded R200 diff + 5 bolt half shafts 4.1 ratio
Powered By Max solid subframe risers
R34 rear 5 stud hubs
Super Now engine mounts (R32)
Super Now gearbox mount
Craig Helps engine block mounts
Custom gearbox xmember (R32)
S14 clutch master cylinder
Braided + custom clutch line
Uras solid shifter (R34)
Enkei wheel nuts
AMG style 17x9+11 (pair) REAR
Mesh style 17x9.5+15 (pair) FRONT
SUSPENSION:
KTS rear strut brace
JIC FLT-FAS coilovers 7k front 5k rear
S14 LCA’s modified/boxed + S13 balljoints
Kazama castor arms
Tomei 3 point front strut brace
A31 front sway bar
STEERING:
S14 steering rack
Ikeya Formula tie rods
KTS roll centre adjustment tie rod ends
KTS aluminium steering rack bushes
GT-1 Motorsports steering bush
BRAKES:
S14 front 4 piston calipers
Project Mu front rotors
Braided front lines
S14 BM44 master cylinder
Hydro h/brake installed under standard console
INTERIOR:
Pioneer front 6” speakers
Works Bell boss kit
Works Bell quick release with flipper
Works Bell steering wheel 330mm
Yashio Factory spin turn knob
Bride Zeta III (Red with gradient)
Bride seat rail
Cusco D1 8 point roll cage
Okuyama Carbing gear knob
Blitz SBC
Sard battery box
Isolator switch
Broadway mirror
Apexi water temp + oil temp + oil pressure gauges + controller
Alpine CD/MD player
Type X passenger seat
EXTERIOR:
S13 silvia front end
Blacked out quarter windows
Flared guards
Resprayed red
0433 830 055 | $10,500
$500- SOLD
$360 firm
$750
0407083177 - Joey
Sard fuel rail brand new never used with all fittings $200
Sard fuel pressure regulator brand new never used $500
Parts will brought from RHDjapan but have decided to used stock rails instead.
Pm me if you are keen
few things ive got lying around
R34 gtt decat its a just jap one - $30
R34 spoiler KR4 silver in colour, couple of small marks - $50
R32 wastegate actuator 10psi - $25
Turbotech boost tee, pretty much new - $25
Pioneer deh-1350 mpg stereo, pretty much new comes with nissan harness for plug and play - $50
Clutch fork pivot ball, New in wrapper part no 30537-40p01 think it suits r33 - $5
and a left hand side r34 weather shield - free
Ben - 0433 987 945
Up for sale is my R33 GTS25T Series 2. Selling as I now have a work car and don't need two cars.
This car is in excellent condition, very clean and unmolested. Only mods are exhaust and pod filter, rest of the car is stock.
Has travelled 106850 KM always serviced, timing belt was replaced at the 100000 KM service.
New front tyres
New battery
New Coolant
New tint
Pioneer 6 stack DVD/CD with remote and vehicle dynamics processor module
Alarm system
Registered till 19/10/13
If you are looking for a clean 33 check this one out, has been owned by a mature aged person and it has not been thrashed, raced or tracked.
Asking for $10000.00 Negotiable - reasonable offers considered.
Phone - 0438 830 788
post-79573-0-10465500-1376022008_thumb.jpgpost-79573-0-11885300-1376022063_thumb.jpgpost-79573-0-16868800-1376022120_thumb.jpgpost-79573-0-66621400-1376022205_thumb.jpg
R33 3" Catback to AMPerformance 4" Twin Tips.
Asking $400.
does anyone know if this would be louder than my hks 3" straight pipe exhaust which i have on. my current exhaust is just under 90db.
Id guarantee it
Ben - 0433 987 945
Asking $400.
Bump - $300 :( Last price drop. I want this gone and I'm pretty sure that $300 is dirt cheap as well.. :(
R33 GTR carbon front lip *brand new*
$300 if gone in the next few days
Buddy club p1 racing originals
Good condition , slight rash on 2 rims
Front tyres ok. rears finished
17x9 5 x 114.3
$700
Call or text any time
0407083177- joey
Edited by joeyy
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
