  • Replies 72
Jim if you want Drive :thumbsup: cool,
or just feed :whistling:
iam cool either way ,
see what numbers come,
as you know now few will be along,
i will talk about sorting a RUN south meet few lads down south then head out do some KM`s :yes:
Hope Few Show up :D ,
but as we know lots have other stuff on,
Craig as you will see some do get out & meet but lots don`t ,
there is a lot of Stagea in Perth but not so many on here ,
well if only 3 of us
is there any POINT :wacko:
I can't make it (unfortunately) I have to go to a renewal of vows (not mine!).
Can't really say no, so I have to catch you next time.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
