* Good News:- We now have a Clubhouse!
* Bad News:- It ain't in Canberra
Addy thanks to Todd and Yumi of JapLink is, 175 Parramatta Rd Haberfield
We are looking for some furniture to kit it out, so have a squizz at Steve-0's thread and comment!
Q. Can a Canberran stay overnight if pooped and short of cash?
A. Only if Shell is staying over too - 'cause she'll have a key (and only if you don't snore - 'cause Shell will bash you over the head if you snore)
Q. What will it be used for?
A. Meetings, AGM, viewing WRC/F1/Races
https://www.sau.com.au/forums/topic/354631-saunsw-clubhouse/
  • Replies 45
Good Questions ^ ^ ^
* We can use the JapLink site 24/7 as we'll be occupying Suite#2 upstairs.
* If the JapLink is being used (daytime Mon-Sat), we'd need to park around the corner in a quiet residential street called Chandos St
* Outside of bus. hrs, we are able to use the yard and with the keys (that an Exec will have), it is secured parking.
* The driveway just needs to be taken at an angle and a low lip car will have no problem. There will be no cover. It's open.
* However, if you've parked around the corner in Chandos St, always go back onto Parramatta Rd. The back streets have deadly speed humps.
Hang on, so let me get this straight.......we can stay there but we have to spend the night with Shell??......hmmmmm :w00t:
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
