Car Stalled And Won't Start, Turns Over, Has Spark And Fuel, Ideas?
I have experienced your exact symptoms on 3 events. 2 of them were the head gasket, and the third was a snapped exhaust cam.
I highly recommend doing a comp test first, as if a cam snapped you will get a bung reading too and then take off the rocker covers.
Hope it works out OK. If your in Sydney/Bankstown local I can lend you a comp gauge if you need be.
I am having the same problems at the moment mine made a small backfire and then started dieing but I was driving on the highway not even Gettin under boost got a second hand cas and still the same. the exhaust temp light came on after it stalled out aswell
Chances of consult cable working is minimal... Unless your CAS is working but way off you wont get any reading from the consult. The fact you have spare and fuel verifies this.
Do the checks I mentioned. Checking coolant and oil for contamination only works SOME of the time when checking for a HG. You must comp test.
And yes, snapped cam = valve meets piston officially after years of anticipation and sexual frustration.
Wouldnt piston and valve love make a horrible crunching sound and eventually seize? eg something I couldn't miss trying to turn it over 100x?
First thing I will do when I get back is check coolant and oil for signs of headgasket, then try new cas, if no go I will arrange to get a compression tester off a mate, thanks for the offer but I'm over in SA.
Appreciate all the suggestions everyone.
sounds to me very much like a timing related problem. usually when your timing is out it will backfire thro the intake. I would be pulling the cam gear cover off and putting the motor at TDC and checking the timing marks are all lined up.
failing that... your fuel pump could be f**ked.. might have enough pressure to prime but then dies off leaving you with bugger all rail pressure.
I am actually thinking fuel reg, it makes weird noises when priming cold however we checked AFRs on 18psi for a long time on the dyno and they never once showed any signs of leaning, however is is possible that it went from fine to the diaphragm dying and having f**k all pressure. The weird backfires are making me think it is timing though.
So order Im going to do things:
Check for signs of head gasket
Try new cas
pull plugs and see if it spins really fast / compression test
replace fuel reg
somewhere in there I am going to get the consult on there, waiting for my mate to get back from interstate.
bunno32gtr a consult cable lets you talk to the ECU via a laptop and you can pull error codes and check the values of basically all sensors.
edit: really hope the battery still has some juice to turn over, cbf getting there and having to hail a random to come jump it.
Edited by Rolls
You have had something go pop and then the motor suddenly stopped. Even if it didnt go pop a sudden stop does not indicate something that would gradually die, IE fuel pump or reg.
Fact is you still have fuel and spark, start thinking more mechanical based.
And no piston and valve contact via a snapped cam would not result in crunch sounds. The cam may have snapped at a point it did not make contact OR it could have snapped and the 1 x piston to valve contact moment would have spun the cam back to a closed position like it did when it happened to me.
Experience at work ^
Ok thanks for that, compression test will certainly show that up if it is what has happened, will try and organise to get one in the next day.
You need to make sure all the timing marks line up first. Stop cranking that engine over. If you have bent a valve, you risk snapping it, then the next rotation could drive the stem into the head. Backfires indicate a timing issue of some sort. As above, make sure those marks are aligned before proceeding......for the sake of knowing you aren't doing any further damage
bottom crank balancer mark needs to line up with the notch on the timing cover. this is TDC. pull number 1 spark plug out and use a blunt object down the bore on top of the piston to confirm this as you rotate the crank. the highest point is TDC.
then.. the two cam gears must line up with their corrosponding marks.. theres a dot on the cam and a line on the backing plate of the cover.
if they are out by even 1 tooth.. something is f**ked
The engine will still start if it's one tooth only. He would be looking for 2 or more teeth out so it should stand out pretty clear.
But yeah, even if it's moved one, something has gone wrong
I took a bit of a gamble and started it again with the new cas, no luck so shut it off. Won't attempt to turn it over until I've got the timing confirmed and done a compression test now.
Thanks for the advice simon and elite, can't be f**ked taking enough tools to take all the front shit off in my back pack so gonna tow it home and go from there.
Worst case and I have smashed everything inside, what's a bare 25 block and head worth these days ~$1k ?
How does it sound at the moment? Like when you crank it are you getting that up/down sound you get with decent compression?
I would have thought the comp would be in a pretty bad way not to atleast start and run rough, in which case the starting sound would be evidently different.
Fingers crossed the comp test comes up OK anyway.
Edited by James_03
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
