  • Replies 216
How about we change the venue? Coz that place was OK, but the brekkie special appears to be getting smaller every time I go there.
My pick would be The Kings
http://www.kingshotel.com.au/index.site.restaurants.54.html
Intriguing but how much is a buffet breakfast at a fancy hotel going to cost?
Edit: Boss, Dale and I used to do breakfast on a weekly basis but we literally worked less than 100m away from each other, first Friday of every month sounds good :)
The kings buffet is about $18 from memory. I was involved in a regular brekkie at the criterion hotel a while back that was only about $15, but we got sick of eating cold bacon etc and moved across the road to Kings, everyone was happy to stump up the extra $3-4.
We could always go all out and go the miss mauds buffet. Its $25 a head, but still one of the most epic brekkie feasts in Perth IMO.
Might make it fkn hard to get out of there and to work on time though.
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
