  • Replies 216
How about we change the venue? Coz that place was OK, but the brekkie special appears to be getting smaller every time I go there.
My pick would be The Kings
http://www.kingshotel.com.au/index.site.restaurants.54.html
Intriguing but how much is a buffet breakfast at a fancy hotel going to cost?
Edit: Boss, Dale and I used to do breakfast on a weekly basis but we literally worked less than 100m away from each other, first Friday of every month sounds good :)
The kings buffet is about $18 from memory. I was involved in a regular brekkie at the criterion hotel a while back that was only about $15, but we got sick of eating cold bacon etc and moved across the road to Kings, everyone was happy to stump up the extra $3-4.
We could always go all out and go the miss mauds buffet. Its $25 a head, but still one of the most epic brekkie feasts in Perth IMO.
Might make it fkn hard to get out of there and to work on time though.
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
    • No sync errors , i have installed AEM disk will return original 360 slot disk and check if there’s any one with running AEM disk could share setup
    • Its been a while! Finally thought to do something on this car, so here we go. This will be a slow burning, multiple posts as I spend 0.5-1hr a day on this job, over multiple days... Full set of GKTech suspension arms!   Step 1: Buy Arms, done! Step 2: Start removing stuff. HICAS was easy. Rear suspension arms are now gone, they were a bitch but breaker bars with long handle extensions, 2 1.5hr slots later, stock arms are off! Next step, remove the hubs and take them to work to press out the bearings and bushings!
