Hey guys, long time no speak!
I was cleaning out my garage yesterday and found a pair of R32 GTR N1 Sideskirts (Fibreglass). They have never been put on a car and they have sat in the garage since I sold my GTR.
I am asking $80 for the pair. Whilst they are designed for a GTR, most fitters around Canberra should be able to integrate it with a GTS-t guard.
For those not familiar with the N1 bodykit, I have included a picture.
Catchyas soon
Pete
Edited by noakespg
