Hey guys quick question, i know this topic has been covered a thousand times and believe me when i say iv been researching for hours!
But im still having some trouble :/
Well today i changed my spark pugs for the 1st time since i bought the car (Recently purchased 3 weeks ago). It had PFR5G-11 in there and i changed to copper plugs BCPR6ES .8mm gap.
Anyway went for a drive and on boost it missfires from 3.5 to 5 thousands revs (a popping noise from the exhaust)
The car is running on 15psi with a highflow turbo and splitfire coilpacks. Didnt have any problems with the previous plugs, so i checked what the PFR5G's were gapped but wasn't sure because every plug had a different gap size :blink:
I read in someones post that :-
- weak coilpacks require a smaller gap so that there can be spark, but itsn't so good for performance (but can eliminate misfire)
- coilpacks with a strong punch can utilise a spark plug with a larger gap (due to being able to create a bigger spark over a larger distance) and can increase torque"
My question is that if thats true what gap size should i be running??
Any help would be much appreciated
https://www.sau.com.au/forums/topic/355444-missfire-question/
Um I'm pretty sure the bcpr6es are not copper plugs not 100% but I am pretty sure the bkr plugs were copper plugs I currently run the bkr6e ones in my car they are copper v plugs and I have not had issues with them I tried running the bcpr6es plugs and I had flats spots and miss fires as you described I dunno y but my car did not like them
hmm what gap size, boost and coilpacks are u running? from what iv heard the bkr6e plugs are abit shorter in length to the bcpr6e.
hey mate the BCPR6ES .8mm gap plugs you have are ok. i run them and countless others. if they are missing at .8 then the problem likely isnt them. but maybe the coils are weak and the previous plugs were gapped lower therefore didnt missfire. you could try gap to .7 and see if its better. the difference between .8 - .7 at 15psi is probably minimal but if it fixes your miss then you could try it out 4 a while. have you read the DIY about insulating the coilpacks to prevent missfire?
http://www.skylinesaustralia.com/forums/topic/119403-how-to-fix-missfire-problem/page__hl__coilpack
Edited by t_revz
http://www.skylinesa...e__hl__coilpack
I thought that having splitfires i didnt have to insulate them, but worth a try i guess.
Thanks for the help mate, much appreciated :thumbsup:
hey man i siliconed the coil packs and re gaped the plugs to .7mm and shes all good now :D
good to hear its ok now, next time you change em id run them back at .8 as i would imagine it was more the silicone that fixed it. if increasing the gap brings the prob back then likely a coil but you could keep running .7 til it gets worse or you up the boost and have to sort it out.
Trev :thumbsup:
  • Like 1
I had a missfire issue after 4500rpm+ with BCPR6ES .8mm. I bought BKR7E .8mm with the 'V groove' and now running perfect.
Running Splitfires too..
Your the second person who said that...thanks il keep that in mind next time i change the plugs :thumbsup:
  • 4 weeks later...
He says that because of the host of issues that come with adding extra boost and assuming the ecu can happily deal with it. It you changed your ecu and had a tune, your power and fuel economy would both increase, possibly dramatically.
Bcpr6es and bkr6es are both copper plugs.
If insulating helps then your splitfires may need replacing in the future. I'd go with yellow jackets, they're a lot cheaper and come with a 2 year warranty.
Is 6 the right heat rating for 15psi? I'd have a good look into that, esp if as you said two people have moved from 6 to 7 with v groove and found an improvement.
There is a mighty long thread on spark plugs worth a read, here
http://www.skylinesaustralia.com/forums/topic/104405-spark-plugs/
Edited by Galois
http://www.skylinesa...05-spark-plugs/
Well today i changed my plugs to bcpr6e the v grooved with .8mm standard gap plug( got them for free off a friend so thought il give them a try), and i had no missfire. I guess insulating the coilpacks solved my missfire.( when i insulated my coilpacks i also gapped the plugs to .7mm at the same time, not knowing if the gap size or the insulation solved the issue) Would i still need to replace my coilpacks? if so how long can run it as is now?
I know that 15psi is really pushing the standard ecu, thats why im planning to drop to 10 or 12psi but i need a another actuator because the one i have doesn't run under 15psi.
Edited by Levy
How long will the current coilpacks last? Completely unpredictable I'm afraid. If the insulation has helped fix it it might be just an issue with the plastic casing, instead of the coils deteriorating themselves, which is a good sign. It might run fine for a month, it might run for 10 years or more, hopefully closer to the latter :D
Yeh hope so...thanks for your input mate :cheers:
Hi Guy`s i have Stagea S2 neo,iI have been PLAYING with coilpack`s since owning my Stagea dec 06 i have tryed few way`s & am still trying different way now have 3 set`s iam doing different,as yet i have found CRC RED URETHANE SEAL COAT which is used for motor winding,this is by far the best way i have try so far,all so look`s good,post-36964-1239969970_thumb.jpg post-36964-1239970199_thumb.jpgpost-36964-1239970677_thumb.jpg,I will post up some more as i PLAY with different way`s.cheer`s chuckie.
You do realise you change the HEAT RANGE of the plug and that was more likely to have solved your issue than the "groove".
i like the that idea chuckie let us know how u go :thumbsup:
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
