Coby extractors - suit RB20/25DE (used 6 months) ** $220
R32 GTSt 4 pot front brakes - retapped with GTS brake lines (direct bolt up to GTS25 Skylines) ** $150
R32 GTSt front disks (recently machined) ** Sold
Parts off 1991 R32 GTS25:
Rear diff, with half shafts ** $80
4 x hubs (with brakes) - Good upgrade for RB20DE Skylines ** $80
Space saver wheel 4 x 114.3 ** $40
https://www.sau.com.au/forums/topic/35568-non-turbo-skyline-parts/
