  • 1 month later...
I have a work colleague that does carbon work and may be able to fabricate some in carbon, I can oraganise a group buy but will need to generate more interest, any1 interested?
get to it man
Got a ballpark price figure, will b about ~$300 + postage, but pricing will lower depending how many buyers there are, so far its just
1. ooskylineoo
2. 75couope
3. ahh 33 s2
4. eiregaus
If had twice the numbers, it will b significantly cheaper :)
Thats just a rough figure from my work colleague guys so dnt try hassling me its not even my pricing lol, if I get more interest ill open up another thread in GB section :),
Spoiler will b PROPER CARBON ..won't be a dodgy fibreglass mash with 1 layer carbon. If goes ahead well be 1 of the very few if not first blokes with it in carbon =D.
Any more takers?
can you get some photos of some of his CF work completed?
How thick would the roof spoiler be in the end? would it be hollow or just a half shell production?
What will he be using to make the mould, need to be sure of final shape.
its still on my car man lols i said might be soon, provided it comes off the back window undamaged which i think it will for sure then yeh i rkn it'll be for sale, stripping parts off this weekend ill keep ya posted bro
$300 lol got mine (non carbon) for like $120..
better off tryin to make an s14 carbon one fit which are like $200..
mine might be for sale very soon :whistling:
$200 for a brand new s14 carbon roof spoiler? where'd u find that from? not 2 mention u hav 2 mod it to fit properly ....I did say it is a rough ball park figure, but as he mentioned prices will drop substantially with more buyers.
I will find out 4 u guys and hopefully get sum pics up in a couple days :)
billy has a carbon fibre one on his 33 again from yahoo.jp deffs didnt cost $300
s14 carbon fibre ones are 200 i think.
http://www.importmonster.com.au/yahoo?cat=0&term=vanquish+r33
$80 sif get carbon..
i paid $30 for mine from memory, freight killed the price
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
