Hey everyone
Been haning to change my stock plates to custom plates or at total wose the Black XX plates if I cant get the ones I wont...
But do you guys get more unwanted attention from the cops for no reason but the custom plates or RB Plates grab the eye?
Have a Bayside Blue S2 Stag and finger crossed...touch wood and everything else I have been left aloneand not pulled over and dont wont that to change due to custom RB plates Or stag on plates or even the black XX plates...:blink: ???
Would love to here what everyone thinks...??
If so ...
PLEASE ANSWER :thumbsup:
Plates ???
Car ???
Color ???
Big kit ???
Big rims ???
Loud ???
Low ???
Eye grabbin ???
If you get what i mean haha
Cheers everyone !!! :worship:
https://www.sau.com.au/forums/topic/355776-custom-plates/
Yeh ive had a full name custom plate on a very low car with big wheelsfor the type of car n never been pulled over.....touch wood! Cops look all the time even had a few give me thumbs up n compliment them lol
https://www.sau.com.au/forums/topic/355776-custom-plates/#findComment-5695704
i have RB.... plates , no probs with cops at all ,
i hate to say this but i reckon it depends all on your age / or how guilty you look !
If your a young driver with a slammed ride and big F..ck off rims = what do you think- maybe , its not the custom plate
  • Like 1
https://www.sau.com.au/forums/topic/355776-custom-plates/#findComment-5700160
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
