I dont know if you are on this forum but if you are I hope you read this. The airport business car park is not the smartest place to practice your drifting. This may come as a surprise to some people, but airports generally have really tight security. Believe it or not, aeroplanes cost a lot of money and airlines like to make sure that they don't get damaged. let alone all the terrorist hijackings and sabotage and shit. so it goes without saying that there are CCTV cameras all over the place and people working in the hangars. Then there is the airport security that drives around checking all the locks on doors. Not to mention the worksite security checking up on things. And guess what else. The AFP also do regular patrols of the airport. So breaking into a car park in a fairly secure and monitored place like an airport is not the smartest idea. It doesn't really make us look good and tends to encourage blitzes on performance cars. So use your brain when you want to go and practice sliding your car and do it somewhere that the people that want to catch you aren't.
Rant over
  • Like 1
https://www.sau.com.au/forums/topic/355790-fking-idiots/
Rant over
QFT
https://www.sau.com.au/forums/topic/355790-fking-idiots/#findComment-5694715
pretty sure it was a 200sx. we got a call from airport security asking about it and when we described the car they said that they had seen them before. only this time they pulled rego off of cctv. apparently its 3 grand just for being in the car park without access passes. and car confiscated for 28 days
https://www.sau.com.au/forums/topic/355790-fking-idiots/#findComment-5696722
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
