i just got car back from auto works i got 2 new same garret 2860-5 put on cause i blew one up
he put it on dyno at wangara autoworks WA and he tuned it to make less power and alot less responsive
still making same boost etc (20 psi)
motor roughly done 30 ooo kms
basically i think he richened it up alot maybee to much ????????
i was making 421 before when old same turbos were on
and now making like 410 with not much punch like it did have before
all this info below is off add and im wanting to know roughly how much power could this car make with 20 psi ?
CP Pistons
JUN Oil Pump
SARD 700cc Injectors
N1 Water Pump
Oil Drain Added To The Rear Off The Head Back To The Sump
TOMIE Oil Feed Restrictors
TOMIE Sump Baffles
HKS Adjustable Cam Gears
Apexi Cams
ACL Race bearing Throughout
ARP Mains + Head Studs
TOMIE Head Gasket
HKS Timing Belt<BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break">Oil Relocation Kit + Cooler
After Market Radiator,
After Market Cooler Piping And Radiator Hoses,
Nismo Airflow Meters,
K&N Panel Filter In Standard Airbox
New O2 Sensors
Huge 600x300x120mm Intercooler
RECENT RETUNE USING NISSTUNE 03/06/09
341rwkw on 18 psi now, on a safe tune
DYNO PAPERS PROVIDED
410HP on -5's with a built 26 ?
Mate your probably a good 100 - 150 hp down on what you can produce.
What exhaust system are you running ?
go to the 26 dyno thread sticky.
Look at all the cars with -5's for an indication of where you should be.
thats what i thought he said he didnt want to lean on it to much ?????? like the motor is built and still has plenty of life ........
i am disapointed in the performance differance who would be a good place to take it to in wa ? has anyone delt with autoworks dont get me wrong he is a nice bloke and he knows his shit but i think i can make more power than 410 hp safetly with my motor dont u think ...
im off it hey f**king thing made more power slightly before but needed a tune and now get a tune and it makes less power to rich i rekon ??????n i am also running 20 PSI SHOULD I BUMP IT UP A BIT TO SEE IF IT MAKES A DIFF ?
WITH SAME NEW TURBOS I MIGHT ADD
ALSO AN IMPORTANT QUESTION HAS ANYONE HAD THROTTLE STICK ON THERE 32 GTR MINE DOES IT EVERY NOW AND THEN ERY SCARY FOOT GOES TO FLOOR HAVE TO TURN KEY OFF ONE CLICK AND PUMP ACCELERATOR AND ITS GOOD TO GO AGAIN ??
IT HAS FAIRLY HEAVY SPRINGS ON THROTTLE I DONT UNDERSTAND PEDAL FEELS SMOOTH WHEN PUSHED ??
Edited by danny14
Post up the dyno sheet and we can see if its too rich.
Tuners can be in a hard position because if they push things too hard and something fails they get a bad name. Although he really should listen to you and see what you want to do.
Not sure what your talking about in the second half of your post??
no i dont have boost plots but before 20 psi now 18 -19 psi
what do you rekon about it ?
Interesting that the leaner dyno result made a heap less power?? Must have had a lot less timing.
What exhaust do you have on it?
I think its worth going back to the tuner and saying your not happy with it. That way you can see if he can get more power out of it or there is a restriction somewhere. You really need to let the tuner know what your expecting. The tuner might have noticed temps starting to increase and so left the tune there. He probably thinks your happy with it until you tell him.
Umm... Just to be clear ....
Are you attempting to pick a 10hp difference (or less than 3% difference) between two different dynos at two different workshops? Presumably on two different days?
Whatever the numerical difference, there were have to be a whole lot of change in the power delivery to pick it up using the "seat of the pants" dyno as well.
Did you say anything about it to Alistair? I would talk to Alistair, see why he stopped there. If you have an exhaust restriction then it was possibly building up a lot of heat and making less power when he tried to put more into it. Or if he simply had no idea what had been done to your engine then he may have stopped for safety.
That power curve doesn't look right to me, what causes that? I've seen a similar graph where it was caused by valve float, and another one where the suspected cause was a leaking wastegate. Surprised nobody has commented on it yet...
i think it has 3 inch exhaust on it i talked to tuner he said leave it for couple of weeks make sure everything runs smoothly then he said we can talk about more power but surely i can make more power than 410 hp safetly with that motor and turbos ?
has anyone had the accelerator prob sticking ?
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
