Hi guys
I have am EXEDY heavy duty Clutch NSK-7056HD in my r33 gtst - just the HD not a button or Cushion. Just wanted to know how much power I can run with out any slip . Also would adding a stronger pressure plate help hold more power and if so what change would I see in the clutch pedal and engagement . My power goal is 230rkw
https://www.sau.com.au/forums/topic/356147-exedy-heavy-duty-cutch/
The official rating for the Exedy NSK-7056HD is 320hp (~240kw) at the flywheel therefore with 230rwkw you'll be really testing it. You can run these with a higher clamp pressure plate to slightly raise this figure however the drive plate really isn't designed for it. In my opinion you would be better swapping to a more suitable kit, such as the R32 listed sports organic, Exedy NSK-7121SO, which is rated to 380hp (280kw).
I got 240rwkw running through one no worries. :thumbsup:
So far so good, dunno how long its going to last but i will cross that bridge when i get to it..
How long have you been running it at 240? Do you give the clutch a hard time?what's type of setup do you have?
+1
I'd go for one of these Jap made items also (and am on my 2nd one) with 230rwkw and more importantly 520Nm ! Stronger clamp rating and importantly stronger drive plate and springs.
Edited by simpletool
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
