Hi everyone
the new tuners are finally in. Testing shows they perform the same (or better in some situations) than the Asuka tuner.
They cost $230 plus $15 postage.
What's in the box?
Gold anodised tuner & mounting brackets
power lead (cigarette lighter lead not required)
2 powered antennas
5m infra red receiver lead
remote control
AV lead (3 x RCA connectors each end)
AV input lead (RCA connectors to headphone style plug that goes into tuner)
If you live in Sydney or southern states, you can contact Andy (Andy65b) to buy one or ask about help with the install if you need to.
Likewise, if you live in Adelaide or western states, you can contact Brad (ducati02) for the same.
Cheers
Leon.
https://www.sau.com.au/forums/topic/356219-tv-tuners-once-again-the-new-asuka/
  • Replies 144
I love DIY, so to make the intall as easy & cost effective as possible I put together some items that you may need.
For Stagea owners with factory antennas, you'll need 2 F-type connectors.
These $1.30 each (Jaycar's 10+ price) and I will add them to the box with the tuner if you ask.
You can power the tuner from the OEM tuner's power, but I think dedicated power is better. When I did mine, I ran a power cable from a 15A circuit in the front driver's footwell fuse box. You can use this 12V supply for other things later also.
I figure you've got to run the IR lead to the front, so it's not much harder to throw the power wire in at the same time. And an earth wire for locking the OEM tuner to the aux input (so it works all the time, even when moving) is a great idea too.
So, here's the wire & connector pack if you need it. BTW, soldered and taped connections work best. But some of these connectors can come in handy, especially when trying to tap into a cable right down in the footwell as it's a bugger to solder down there.
What do you get for your $8?
6m of black & 6m of red hook up cable (16 x 0.30)
3m of white (not sure why, but it may come in handy)
2 x eyelets for connecting an earth under a screw
2 x quick wire connectors
4 x 3-way scotch-loks
A relay or 2 can come in handy depending on what else you want to control. I used one when I put in a reverse camera so that it applied an earth to the C1 (or Cont1) terminal to force the screen to the auxillary input.
If you are not sure if you need one, just let me know what you are wanting to do & I'll see if I can offer advice. I may look at posting some diagrams later of how to wire up for typical applications.
Anyway, I have relays with the wired bases available for $5 each (Jaycar's 10+ price is nearly double that!) so let me know if you need any when ordering.
I have an Eclipse double DIN screen that I needed to connect to the tuner (video also goes to factory screen) so I needed a 5m RCA-RCA cable.
The tuner comes with a cable but it's not long enough to reach the length of the car so I bought one from here http://www.4cabling....o-Cable-5m.html & it turned out to be really good quality for ~$15. As an aside, they can take a few days longer than you'd expect for shipping.
The normal mounting spot for Stageas is in the rear cubby hole adjacent to the OEM tuner, but space can be limited. When I plugged in the RCA lead, I thought the bend radius to be too tight, especially for the heavy duty video coax (see pic).
To save kinking this cable I used right angle RCA adaptors. I you are thinking of using a space like this, these could come in handy. You can buy them online or I have them for $1 each.
Most people will also want to feed the video & audio signals into the OEM tuner so that it displays on the factory screen and plays thru the sound system.
You can make these yourself if you're a little bit handy. This is the one I made for my setup, but it's only for the video since my sound is via an aftermarket system & connects via AV (RCA) leads.
If you would like me to make one up for you, please ask. The price for a full set (3 x RCA) will probably be $40, but that may change if I find it taking too long. I would encourage anyone to have a go themselves. There's a few threads/posts around that discuss this & I'll try & link them at the end.
One thing I didn't try to offer to supply was a switch to force the OEM tuner to the auxillary input. Everyone would want something different, depending one where you wanted to mount it & personal preference. I decided to use a blanked off switch position, the only one I had left, to put 3 small switches. the top one is for the TV.
Whenever it is flicked over it puts an earth on the C1 terminal & the tuner is displayed on the factory screen. Turn it off & I can see the fuel consumption green leaf or compass etc.
I can vouch that these tuners are great value for money. The USB input is great also for watching movies and playing music.
The AV1 input is fast when switched using the 12v reverse wire. It dosent have to think about going in reverse like some tuners which can have a delay. Its instant.
AV1 can be used for other inputs not just reverse camera.
The powered antenna that are in the box worked quiet well in the GTR around Adelaide. Having them powered definately makes a difference compared to the non powered ones.
And the tuner is nice and small for easy hiding or showing. Id make a clear window in boot just to see the gold tuner there.
Another cable I would run down the front is a 5M USB extension and put it in the back of glovebox or get a 90deg USB bend and mount it where the ETC unit is next to dvdrom.
This makes it easy for pluging in USB if your tuner is hidden.
Then all you need to do is remove the video block for off road use (can be done with english conversion)
Hi Josh.
Just PM me your address & I will post one out to you. If you just want the TV tuner it will cost $245 to get it to you (or if you are driving south past Byron Bay you could pick it up & save the postage!).
Since your car is an M35, at the very least you should get the F-type connectors (2 of for an extra $2.60) so you can use the factory antennas for best results.
If you have some multi strand wire laying around then you probably don't need much else. You can always add a switch to bypass the in motion cut off, a USB extension cable, reverse camera or RCA leads for an Ipod connection later on. There's lots of nice options you can look at doing. You can get some great tech mods done in an afternoon that make you driving experience so much better than driving some old Volvo :thumbsup:
Hi Brad. Thanks for you input. When you say you can remove the video block, you mean as an extra job whilst you are doing the english conversion, right? I was never offered this as part of my my english conversion.
Yes programatically it can be done. But its for off road use only
if i install it closer to the front of the car is it a straight plug and play unit or is there more to do than what i expect?
No point putting it in the front of the car as the OEM TV tuner is in the back and the access to the AUX input is through the OEm Tuner.
ahhh gotcha. I was under the undstanding that i had to pull the dash apart and the tuner is in there. Thank you for clearing this up for me. Where abouts in the rear is it located? Close to the passenger rear removal panel in the previos pictures.
It is located just in front of that box. To access it properly you will need to pull the side panel off.
great info guys.
commsman: in your travels, have you come across a tv tuner with an hdmi receiver? I'm keen to run hdmi out of my phone and into the factory A/V system. The phone (samsung galaxy s, soon to be a galaxy s 2 ) will also do RCA via 3.5mm, but it's a noisy signal that i think would need particularly high impedance inputs to counter this :\
edit: forgot to mention, I'm aware of the hdmi to rca convertor boxes available from ebay, etc, but with the A/V signals already bouncing through so many boxes, i'm keen to avoid any extra equipment if possible...
Edited by cha_cha_
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
