  • Replies 128
pete,
need:
battery hold down (with bolts)
GTR fuel tank (with straps)
windscreen wiper cowl cover (with screw insert covers- intact please)
headlight seal (rubber panel behind headlight) with clips.
GTR bonnet catch brace/support
and quite a bit of other stuff I can't think of at the moment :)
need:
Battery hold down $20
Fuel tank $50 but no straps
Bonnet catch etc $20
Don't have the other bits. Postage will be $40 due to size of the fuel tank
Pete
bonnet catch : catch + mounting bracket ?(IE the piece that ties it to the top radiator panel and the lower panel?)
the rest is fine. what happened to the straps?
gday mate if u dont sell the fuel tank im interested as i heard gtr tanks are plastic and i have a gtst that i think has a internal rust issue, heard its a possible swap/solution any one heard if this is true also?
Just checked and it doesn't have the mounting bracket. Straps went to the scrap yard.
No worries mate will let you know if Chris doesn't want it
update 28/3/11
gtr front lip $140
scratched and one minor crack
Black R32 Gtr front guards
No dents but have some scratches, overall good condition
left available $200
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8812.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8807.jpg
Tail light in black $80 each, excellent condition. Also have white and grey
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8795.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8876.jpg
hecktic plumback turbo smat $120
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8872.jpg
Front indicators $40 each
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8785.jpg
Apexi pod filter (almost new) $150
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG00050-20110307-1705.jpg
R32 Gtr fuel tank $50
Gtr rear diff in good condition $350
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8842.jpg
gtr front diff with welded on extension(you dont get the lsd centre just the casing) $200
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8840.jpg
stock front diff with diff centre $250
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8839.jpg
ohlins coil overs front and rear(r32 gtr) $400
rears good fronts questionable
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8838.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8837.jpg
tanabe suspension height and rebound adjustable need a clean but work well $400
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8836.jpg
Nardi steering wheel with boss kit $60
the right hand side is a tad warn in the pick
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8849-1.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8850-1.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8851-1.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8852.jpg
hks oil cooler $350
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8891.jpg
gtr key barrell $100 with key
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8884-1.jpg
jap fuel rail twin in one out alloy with fitings and fuel reg $300
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8883-1.jpg
fuel setup
044 pump
earls fitting
$300
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8881.jpg
fuel setup 2
040 pump
$250 has relay
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8880-1.jpg
gtr front brakes with rotors lines and calipers $300
Other parts - pics not available
Complete aircon setup $150
Front drive shafts $100 each
ABS unit $120
Front Gtr hubs $100
Lower control arms $50
R32 Gtr doors $100 each (white) non side intrusion
turns out me tanks stuffed to rusty to be worth cleaning so im stuck with out a car with out one haha so looks like i gotta get on one so that would be good thx mate.
go for it. I'll grab another.
pete,
still want the rest of it though.
pete,
thx mate
fatz was either of those fuel step us used with this tank? as in could i make a complete setup for my r32 gtst with what u got? as then i might to interested in such items also as me fuel pump will probably need replacing one day soon also as of the amount of rust in tank? im going to try and clean up my fuel rail and gott my injectors into be cleaned atm.
hey mate,
do ya have a l/h turret (door apature) mould
dash centre demister vents
r/h inner door trim weather strip
l/h reverse light
let me know cheers
mold? get me a pick so i know what you mean
demister vent i actually have one in perfect nick $20( these are impossible to get off)
no door trim
reverse light yea should have one 30 bux
pete
thx mate
plugs into your stock setup
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
