got this spare with a car i bought, someone told me its a vlt rear housing (.63) and has the same stud pattern, but i dont know what the specs are, aside from the fact that it has been high flowed.
also, does anyone know if the highflowed components (wheels, housing etc) would be interchangeable with an r33 s2 rear housing? as ive already had a custom dump pip made to suit it.SAM_0041.jpgSAM_0039.jpg
https://www.sau.com.au/forums/topic/356595-what-kind-of-turbo-is-this/
do not use this turbo on a skyline. they are shithouse old design. i had one and it was rat shit.
You might be able to get the standard housing machined out to suit depends how big the rear wheel in that turbo is.
Sell it and get a better turbo, its just not worth using the old VL design the stock turbo will be better.
That "thing" , and I'm being nice , is the dreaded bastard hi flow bitzer turbo . The housings look a bit like RB20 on the compressor side and T3 on the hot side . The hub of the turbine looks a bit like a Hitach HT18S one .
Probably bore everyone but .
1)Comp housing inlet bored out a lot so a big wheel for a smallish compressor housing .
2)Hitachi turbine big which is fine for a Ser 4/5 RX7 Rotary but iffy on a bastard hi flow .
3)Note the size of the waste gate outlet hole on the T3 turbine housing . Maybe Ok for a dinosaur 70s era 150 Kw T3 but not for any current (in the last 20 yrs) performance engine .
I would rather run your engines std turbo if in good nick than that thing .
A .
well actually its an rb30e+t in an r31 that it would be going onto, but now im thinking ill just keep the 33 s2 turbo on, even tho it may be a bit small for the 30, anyone offer a suggestion of what that highflowed one would be worthe to sell 2nd hand?
It would probably prefer the Hitachi BB VG30 turbos larger OP6 turbine housing if you can find one .
From memory an RB30ET made 153 Kw from its 50 something comp trim small turbine series T3 turbo in 0.63A/R turbine housing form . An RB 25 with the above mentioned turbine housing made I think 206 fly Kw in an R34 GTt .
A .
it appears to be:
.63 VL turbo's turbine housing with a R32's comp housing, bush bearing setup
Standard VL turbo turbine wheel or TB34 turbine wheel with a 8~12 degrees crop running a 56T 71mm comp wheel. It should be ok for about 250~260rwkws on Rb25det with average response using a strong actuator.
Need a none restrictive oil line for Rb2x engines. You will need his dump pipe as the internal gate part is in it.
anyone have any advice on if this turbo would be any good for an rb30et, drove to the dyno the other day (very sedatly), got out and the turbo was leaking oil and smoking. f**k. so im thinking about putting a rebuild kit thru the hi flowed one and putting it on instead before i head back to the dyno, what kind of rebuild kit would i even have to get? or would it just be a mix and match on seals and wheels?
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
