Hi guys,
just trying to get as much info as possible on the Hancook z221s. I have noticed that times are getting slashed by those who are using these and they are now the tire of choice in japanese time attack (hence why i got a set to compensate for my driving abilities :P )
Is it a better compound? or the fact that they are just wider? i have two examples where an Evo that previously went 41's aound EC on 265's Ao50's
ran a pb at the latest round of sprints dipping into the 39's on 295 Z221s and the other being a FD in SA going 3 secs quicker throughout the day when switching from Dunlops Dz03's in the first session
EVO - P2
http://www.natsoft.com.au/cgi-bin/results.cgi?26/02/2011.EAST.S1
FD - P2
http://www.orion-timing.com/1028/20110306/1028_20110306_001_03_01.htm
i guess some useful pointers would be what pressures some people run on there particular tires.
My experiences with advans that yielded the best times are
A050's - 34psi cold 36 hot
Ad08s - 32psi cold 34 hot
i was suppose to try out my set last saturday at the sau/renew track day but time got the better of me with getting the car ready.
I will definately post up some results as soon as i get out there
:cheers:
Steve
https://www.sau.com.au/forums/topic/356603-hankook-z221s-vs-ao50sre55sdz03s/
As to the times from Kalis in the EVO, he also has gone wide body with wider wheels and track from last year so could be a combination or upgrades? But I’m watching people on Hankook’s very closely as well to what tyre will be best for time attack. The 26th Feb at the creek was a very worm day with very high track temps so maybe it did suit the Hankook’s more will be interesting to see feedback from cooler day eg winter at Wakefield.
Anyone know track temps that the japs would see at their time attack events?
Will look forward to reports once you have tested them also Steve keep us posted with results.
Just keep in mind you can't really rely on the "top" time attack teams to get a real and accurate picture of the pace of a tyre.
They use the tyre in a different way to mere mortals like myself, I want a tyre to be both fairly quick, but also usefull for several track days. We all know how expensive they are!
The top teams use the tyre completely differently, typically there is a "sweet" zone, a zone where that particular tyre will go outrageously quick to set "the" time, but after that one lap, it's past its prime and will never be as quick again.
At EC last year..... it was worth 2 seconds using the tyre correctly. TWO seconds! But after that, the tyre was effectively a rag.
On a typical mid 20's day, around 6 psi mate.
Obviously it's track or road dependant, ie, how hard the tyre and brakes are working.
On a typical day at Lakeside, I'll kick off at 28psi cold, but first session they'll be up to 36 or so, so I bleed back to 32 and there they stay usually. Obviously I check them during the day to ensure there's no issues.
Anyone know what the 295/18's are worth a pop?
Nice to see another tyre though. Seems in GTR sizes they come in both S and MH compound. Would be good to test regardless.
I.ve been quoted just over 500 a corner for that size from a local guy who deals only in slicks and semi's Snowy.
Over 200 a pop cheaper than the direzza's. Gotta be worth a try at that price.
  • 3 months later...
I normally get between 6-8 psi more pressure from cold to hot too, depending on what corner the tyre is on. LF cops the most work (and therefore pressure increase) at Lakeside.
I set my pressures a bit differently to some though. I find my car is always faster in the first few laps of a session - probably due to heat soak as the session goes on. My top speeds continually seem to drop off each lap, even if the corner speed onto the straight doesn't. So I am happy to let my tyres go ~2-3 psi higher by the end of a 5 lap session than I ideally want them, to try and have them at their optimum pressure at the same time the car is at its best - lap 2 or 3. That's my theory anyway.
  • 3 weeks later...
i know with the older 048's we ran in the utes, 1810kg,, 235's we set out at eastern creek at 28 and bleed them off at 40. they seem happiest at 40-45psi hot. heavy car and probably not relavent. but worth knowing i spose.
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
