Hey - yeah sorry for the delays..... We bought a house, and have moved twice since my last post. Just moved into our new house last Friday so i'll get back into it in the near future.... My car is in a shed now off the street, so I tinker with it again without having to worry about getting hit by cars etc. Although, all my electronic test equipment and tools are still over on Kangaroo Island at the moment so prolly can't do much till I get it all over here sometime in the next couple of weeks...
Jeff
  • 4 weeks later...
Maybe someone can help me out. My 32R dash has ABS and 4WD lights on that didn't go away with a reservoir flush and fluid top up. The mechanic reckons its an error 11 or 13 which is consitant with what I've read hear.
I took the centre console G-sensor out this morning had a look at it however there doesn't appear to any leakage on the PCB. What should I do next? I don't mind taking it to an auto electrician but I don't want to pay through the nose for a 50cent capacitor and 10seconds of soldering. I split my time between the Central Coast and Sydney BTW so any recommended autoelecs?
I'va attached pics of what my G-sensor looks like-
Hey,
If i ever get my butt into gear and finish this new replacement I would point you towards that. However, in the meantime, take a look at my first post in this forum. The caps don't look like they have leaked ( bit too fuzzy to say for sure). I would try adjusting the pots and see how that goes. The procedure is very simple - all you need is a multimeter and a little screwdriver.
Jeff
Thanks Jeff, I'll buy a multimeter this week and detail what results. I only removed the G-sensor under the sensor console, is there a chance the lateral G-sensor has crapped itself and results in the ABS & 4WD lights being on? If so I'll take that one out and look for capacitor leakage.
Echoing words of previous members I'm very keen to see a replacement G-sensor for these cars, I looked at a handful of gtrs in my price range (<$15,000) before buying mine and they all had the ABS and 4WD lights on!
Looking forward to more developments and having a proper Gt-r.
I now have an automotive multimeter and plan to do the voltage drop test described on page one. I haven't done this test before and want to be clear on some things relating to the picture Jeff posted with the instructions. The picture of the G-sensor circuit board on page one has three yellow circles, when 'adjusting the pots' in red circles I have the black lead of the multimeter on a single yellow circled point for each adjustment. Please correct me if I'm mistaken
What I am confused about is the description "voltage between the car body and three yellow pins", does the multimeters red wire attach to the car body, essentially grounding it or to the positive terminal of the battery as I anticipated?
I'd like to do the adjustment in the next couple of days so let me know
Hey, here is a more detailed procedure:
1.) Move your car to a LEVEL sport - **important**
2.) Connect to the black wire from the multimeter to the car body (Car body is ground - negative battery terminal is connected to it)
3.) Set the multimeter to measure "VOLTAGE" with a range of say 0~5 volts (or the next highest setting)
4.) Make sure your G-Sensor is plugged into the car and bolted down as from the factory but with the cover removed
5.) Start the car. Make sure the handbrake is on lol.
6.) Take the red positive wire from the multimeter and hold it *****CAREFULLY****** on one of the yellow pins (note there are three colours on the picture: Red = pots, Orange = capacitors, yellow = test points)
7.) Adjust one of the pots (I'm sorry I forget which pot corresponds with each test point - just use trial and error) so that the test point reads 2.50volts
8.) Repeat step 7.) for the remaining two test points.
9.) IMPORTANT!! After all the pots are adjusted turn the car off and restart it - ***re-measure the test points again to confirm they are all 2.50volts
10.) Turn the car off and restart - you should no longer have a G-Sensor error.
Hope this helps.
Jeff
Thanks your intructions made it very easy. The problem is though that the lights are still there. before adjusting the voltages they were all over the place (2.03-2.85), after a bit of fiddling I got them within a 2.50V ballpark (2.48-2.52), i wanted 2.50v exactly but the values keep oscillating evening when I wasn't adjusting the pots.
Is it time to adjust the lateral G-sensor under the dash or should I try and get 2.50V from the central sensor?
The funny thing is though after turning the engine on the ABS and 4WD lights went off for 1-2seconds then came back on. odd
Any advice will be appreciated I'm starting to think that I should stuck with carburetter cars
Any advice will be appreciated I'm starting to think that I should stuck with carburettor cars
Two interesting points here.....
1.) When you say the value was oscillating - what was the range is was cycling between ?
2.) Is the 4WD light off for a longer time than it was before you adjusted the pots ? (May indicate the system needs bleeding...)
**Check the computer in the boot now and see what code it is flashing. (Very easy - or if you are not sure have a quick search on this forum) Hopefully it is something other than the G-Sensor now....
Regards,
Jeff
I had another go today and got 2.5V for all of them, to no avail. Will tomorrow do further diagnostics.
To answer the above questions
1) it was oscilating between 2.48-2.53 ish, this only happend when the engine was running, I presume due to vibration? I was able to get 2.5 exaclty by having the ignition on all the way before kicking the starter motor over
2) the lights are off longer than before (subjective opinion) , but still come on, Bastards!
Will keep y'all posted if I make any developments.
Yeah next step is to check the computer in the boot and see what code it is now flashing out.
Jeff
Ok so I've just ran the ATTESSA diagnostics for the computer in the boot and got error codes 11 & 13; 11 Fore-and-aft G sensor 1 or circuit
13 Fore-and-aft G sensor 1, fore-and-aft G senstor 2.
Can anyone suggest what I should do next? I have adjusted the voltages in the G-sensor underneath the centre console(all within coohee of 2.5V), is there a second G-sensor that needs adjusting, it has been referred to in other posts on SAU that there is one behind the dash/glove box.
This is becomming very frustrating!
I have also read on SAU that adjusting the Throttle Position Switch (TPS) voltages, and cleaning/checking each wheels ABS sensor may correct the problem, does anyone have experience with these methods?
Thanks in advance
James, I think most of us have the same issue with the G Sensor (codes 11 & 13).
I've tried Jeff's fix, it does work... only temporarily tho.
I think our only salvation is if he builds a new PCB. Sit tight.
I'm not an electronics tech, but even though the caps aren't leaking, is it possible they have lost their capacitance.
Spot on...
Jeff
Edited by datsun_1600
AHA! So thats a potential reason why I still get error 11 or 13 after adjusting the pots to 2.5V.
I have the G-sensor out and would like to take it to someone with a clue on how to fix these things/check the capacitors. Any recomendations? autoelectricians, computer technicians, Jeff......?
I split my time between Sydney and the Central Coast and any reference to helpful/experienced people would be great!
Take it to an electronics repair place. eg. T.V. repairer.
Well I replaced the caps and set all outputs to 2.5v, it seems partially better. I'm still getting the ABS and 4wd lights on every now and then.
Mines throwing a code 16.
Strange thing is, if I start the car and immediately let the clutch out and start moving, the lights stay out and 4wd is working. As soon as I stop and idle the lights come back on with code 16 again??????
A friend is loaning me his G sensor to try.
Edited by countryhick
In case anyone needs more pics or to see how i fixed my G force sensor and what my problems were see the link below, i posted at another forum im a member of that has a electronic subsection, you may need to reg to view the pics though.
http://www.austech.info/electronics/68309-gtr-gforce-sensor-fix-help.html
It been working fine for a week now, just a burnt out Cap that cost 38 cents.....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
