Wanted to know if it worth while upgrading to a stock 27mm R33 gtr rear sway bar on my C35 laurel which i assumes carries the same bar stock as the R33gtst....I'll measure it to confirm but its visually much smaller than the gtr one.
I dont have access to whiteline or any other fancy brands so this is pretty much my only option so i just want to know what adv / disadv will i notice particularly if the car will still be predictable as its strictly for the road,... it also has a 1way mech. diff and 255rwkw, rwd obviously
https://www.sau.com.au/forums/topic/356882-rear-sway-bar/
For a rwd car, in general people change the front sway bar first to increase rear traction/decrease front traction. If you increase the size of the rear only, you will end up with probably better body roll control but also less drive/traction coming out of corners as you may start to lift the inside rear wheel giving much less mechanical grip available. It will also change the natural understeer tendency more towards oversteer first on limit in general.
So my guess is no? Unless you were chasing some specific handling behaviour or bug in which case you would be much better off with an adjustable sway bar.
https://www.sau.com.au/forums/topic/356882-rear-sway-bar/#findComment-5709349
Hi,
We are not sure wher you measured from but a GTR rear bar is not 27mm.
The usual upgrade there is that the GTR is solid VS the hollow rear but they are the same diameter from what we know of and no where near 27mm.
We have dealers and Suppliers all over the world so if you click dealers on top of the page of our website My link you will find one near you and we have a list of rear bars that will suite you well and you will easy have access to them. If not email us at Email me
Also if you look around there are many sponsored traders on here that sell Whiteline products you could purchase through
https://www.sau.com.au/forums/topic/356882-rear-sway-bar/#findComment-5723294
yeah i did the GTST to GTR sway bar upgrade on my 33 GTST.
Made it stiffer with less roll. Iv also got ciolovers in (8kgF, 6kgR) so i do find it harder to get the power down. To compensate i just threw on some sticky 275's. Best of both worlds now ;)
https://www.sau.com.au/forums/topic/356882-rear-sway-bar/#findComment-5723484
Hmmmm...
Yea man the R33 gtr rear is between 26.5 - 27mm......That has been confirmed a few times around here in various threads
The R32 is a little smaller and the R34 gtr is the smallest of the batch
What size solid bar will equal to a 27mm hollow?
https://www.sau.com.au/forums/topic/356882-rear-sway-bar/#findComment-5724736
now you are asking a very tricky and technical question that i think you are dreaming if you are 1-even going to find an answer. 2- find an answer that is correct as oppposed to speculative...
Otherwise, id say the bottom line is that these sway bars and this 'swap over mod' would have very little impact, especially when we usually are throwing all sorts of other things into the equation like coilovers (stiffness, damping, ride height), strut braces, engine dampers, different size rims and low profile tyres, different width tyres.
Se where im coming from?
https://www.sau.com.au/forums/topic/356882-rear-sway-bar/#findComment-5725019
We'll its been a wk since driving around with the gtr bar and there is a noticabe decrease in body roll and so far no negative results tractiion wise
I would have liked it a little stiffer tho........i think....
So if you can get your hands on a R33 gtr rear bar for small money and able to swap it out yourself id say its a very good upgrade
https://www.sau.com.au/forums/topic/356882-rear-sway-bar/#findComment-5745920
yeah its a good mod, especially if you can pick one up cheap. I got one for free when buying some suspension off a GTR :)
it is worth noting tho that there is only so much an stiffer sway bar can do. If you want it harder you are going to need to change those coilovers...
https://www.sau.com.au/forums/topic/356882-rear-sway-bar/#findComment-5746402
Yea man already got some tiens which were stiff as fu&k but i swapped out the springs with some jic ones and that eased up the ruggedness a lot ....its still firm tho and the damper setting is all the way down
I think i'll fiddle with the damper a little and see how that goes....dont want to compromise tractiion tho
https://www.sau.com.au/forums/topic/356882-rear-sway-bar/#findComment-5747366
so basically using a 33gtr hollow rear sway bar as an upgrade for r33 gtst is a bit dissapointing?
i wonder how it compares to the 22mm whiteline rear swaybar.
and what other aftermarket alternatives are there, besides whiteline?
Edited by Munkyb0y
https://www.sau.com.au/forums/topic/356882-rear-sway-bar/#findComment-5747385
If you can get your hands on Cusco sway bars, they're a quality piece of kit.
https://www.sau.com.au/forums/topic/356882-rear-sway-bar/#findComment-5747460
It's a steel bar.
If you could tell the difference between a Cusco and Whiteline item of the same diameter I'd be very bloody surprised and you'd be kidding yourself big-time!
There is nothing wrong with the Whiteline kit and if you are paying more $$$ for your metal bar it is simply for a brand name which is not worth a pinch of shit on the track or anywhere else in the real world.
https://www.sau.com.au/forums/topic/356882-rear-sway-bar/#findComment-5748245
what ever happened to selby sway bars? surely there are/were other brands.
The Selbys name was bought by Fulcrum, along with some intellectual property. A bunch of the old Selby's staff now work for Whiteline; I believe.
I also had some excellent work done by Todd Selby, of Signature Sway Bars. He made me 8 sets of beautiful custom NM35 Stagea Sway Bars. He mostly does low volume/ one off, custom stuff. Great guy, couldn't do enough to help.:worship:
If you like I can put you in touch with him; but I'm making an enquiry for you, regarding your PM on monday. I'll let you know what's what.
https://www.sau.com.au/forums/topic/356882-rear-sway-bar/#findComment-5752474
Springmakers will make custome swaybars if you give them the stocker for a pattern and tell them how thick you want the bar. In my city for about $300. Or you can get Japan sourced big name big ticket aftermarket stuff.
https://www.sau.com.au/forums/topic/356882-rear-sway-bar/#findComment-5753215
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
