I have been seeing an increase in skylines in the area and thought It might not be a bad idea to see who's about and what they are doing with there car's.
So list it out like this:
Car: 1992 R32 GTST.
Colour: White with black boot and bonnet.
Mods:Pod, Exhaust, Coilpacks, FMIC, Nistune.
Plans for the next Mods: Turbo and Injectors
Owned for: 8 months
Any other imports(this can be current or previously owned): R33 GTST 300zx TT
anything else you can think of feel free to add, Wouldn't mind getting a north area cruise group happening or even a meet and greet.
Yeah man I have a r32 gtr silver no. Plates is slo26 but I live in kallangur mods r twin t517z kls low mount manifolds 3.5 inch dumps PFC 740cc injectors splitfire coils sard fuel pressure reg denso pump twin z32 afm boost 2 twin plate osgiken clutch the only problem is there's a noise in the head maybe bent valves so that's what's next on the list can't wait to get it fixed then I'll have the 300awkw monster back on the road
we just purchased an 1993 R33 GTS25T 4 door turbo
its silver and auto (missus cant drive a manual and it will be somewhat of a daily for her)
getting it rego'd next week
its stock as a rock except a turbo timer
even has the factory casette deck and an air purifier in the parcel shelf!!
we are at Narangba
I drive a 1990 MX83 cressida with a 1jz in it
its also silver with a big PWR front mount hanging out the front
has big single turbo running 18psi and a 3k high stall auto (going to manual as soon as I can afford it) 3" exhaust with twin 3" pipes(drift style)
good fun suprising the kids around here haha
I live in the north as well and own a wine red R32 GTS-T. I Have owned this car for about 10 years nows. I just can't let go.
Mods - PWR radiator, GTR Injectors, z32 afm, Bosch 040, Returned ecu, HKS GT-RS turbo, Tein SS Jap spec suspension with EDFC, cusco LSD 2-way.
Engine is healthy but is leaking oil out of tapet covers again Grrr.
Car make a fare amount of power at 23psi but I have never dynoed it to get the true rwkws reading.
I will be getting a new EBC and nistune very shortly and next year maybe sway-bars and cams.
Edited by RedDrifter
we are at Narangba
Nice R33 is a good choice my missus wants one because I used to have one and she loved it.
I want to see this cressida it sounds badass
the cressida is pretty ordinary in the looks department
but it goes ok
need to get an aftermarket computer for it to really tap its potential
just picked up a set of Bigwin side skirts and rear bar for it today just need to get them repaired (has some damage) and need a front bar
all in good time.
The skyline will get the usual mods once its registered and just replace things as they break
Welcome to the thread, That turbo is some seriously expensive kit man, How does it perform?
but it goes ok
all in good time.
Looks are not everything. I am planning on doing a sleeper as my next car.
I bought the kit from Nengun 4 years ago when the AUD was strong against the yen. Picked the kit up for a real good price.
The turbo is as big as you would want to go for a street RB20.
Response vs power output is incredible.
well our skyline should be rego'd on friday woot
started it on the weekend and it made the rattle sound at the front near the timimg belt cover area so i am guessing its in need of a belt/ tensioner/ bearing change from all the youtube and forum reading ive done????
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
