Turns out my Fuel pump needs to be upgraded again :-(. Car made 405rwhp on 20psi with a blend of 70% pump fuel and 30% E85. Impressive numbers i guess but the fuel pump was maxed out. Upgrading to a 400L Walbro for now till i can save some $$ for a full external setup. Also injuectors will be next on the list as they are reaching their limits
What pump was in it currently?
I went a bosch 044 in tank mount and 660cc injectors but I will not be going e85 as it is a pain in the ass to get here.
Walbro 255 from memory. Going to 400 for now as a quick fix till i can afford a full setup. I also have 740CC Nizmo Injectors. These will also be reaching their limits once the full E85 tune is done. May look at some 1000's.
E85 just seems to put a lot more strain on these parts compared to going with a bigger turbo and hitting these HP numbers on Pump98.
Hopefully it will see closer to the 430 number by the end. Which is a lot more than i expected
Ive got a maroon R32 GTST. I work at Grand Prix Mazda at Aspley haha, Hope to see yous all around :)
Hey mate, welcome! Feel free to come to our dinner this week and meet some of the club members and share some food and beer. http://www.skylinesaustralia.com/forums/topic/425064-dinner-and-chat-prt-16/
SAU drag day is happening in July.
All you horsepower junkies need to come join us!!
June mate...
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
